Question about Makita 6825 Factory Reconditioned Drywall Screwdriver
Pro-Tech 10" drill press model 10162. Quill travel adjustable?
My table top press seems to only have 1" quill travel. CAn I increase the trevel to drill deeper holes? I can't find the manual at home or online.
Thanks
  • 843 Answers
There is probably a depth stop collar with a thumbscrew on the shaft which has the three handles attached to it. This collar would be about two inches in diameter. All you have to do is loosen the thumbscrew.
Posted on Apr 26, 2010
Quill not feeding in auto
sounds to me like a gear tooth is chipped ,broken or worn out, in your gear box (we are talking about auto feed aren't we?) or the engaging mechanism is faulty .....dismantle and inspect if you have the know how?... pete
Mar 11, 2014 | Drills
I have a Delta 17-950L drill press. The table is perfectly level according to my level. In checking I find out that the chuck is not coming down completely vertical. An eighth of an inch in a four inch...
You don't want the table to be perfectly level, it does need to be perfectly perpendicular to the quill. If the motor housing or quill is not be perfectly straight up and down, as appears to be the case with your drill you will need to square the table to the quill, both left to right and front to back.
Feb 10, 2011 | Delta Laser Crosshairs Drill Press...
When the handlebars are turned, the wheel does not turn with them. Kettrike Air Navigator tricycle
  • It sounds like the quill insert is loose. The handle bar connects to the stem, the stem connects to the quill, the quill connects to the steerer tube.
  • while sitting on the bike, tighten the quill adjustment bolt a half turn at a time until the handlebars turn instantly with the front wheel.
Aug 19, 2010 | Cycling
I have a 17 inch Craftsman Drill Press model 152.229010. I was moving it out of storage and it fell over. The center pulley on the top that adjusts the speed came loose. Does it have a screw from the...
The pulley does fit loose so the quill or the spindle can ride up and down on it. Just has to be snug enough to grab it and spin but loose enough to move up and down. Hop this helps.
Jun 21, 2010 | Drills
My 15" Craftsman drill press will only feed about 5" before it stops. Stop nuts are at limits and not touching feed mechanism. I loosened the quill return spring slightly (about 1/2 turn) without any...
5 inches of travel is about one turn of the gear on the press head shaft. It sounds like there is something in one tooth of the press head shaft hand gear. The only way to find out for sure is to open the upper chassis and inspect the gear for the drill press shaft and hand depth adjustment gear.
Thanks for using Fixya.
Kelly
Mar 22, 2010 | Water Heaters
Where do I get parts for a clarke drill press model bt1029?
the part number I found is BT1029-0038 for the quill spring and you can contact them at 1-800-227-9603 and see about ordering the part. If I have helped you would you please rate this response accordingly and thank you.
Sep 24, 2009 | Clarke Power Products Clarke 16-Speed...
Excess play in spindle. How do you get to the quill and bearings? Is a pulley puller what is needed to get the pulley off?
The quill is separate from the pulley. All you need to do is remove a bolt on the opposite side of the handle, this should let you uncover the return spring. Take the spring off and pull the handle out, on the right side. the quill will then come out the bottom
Aug 08, 2009 | Drills
Seized cylinder for up and down control
I have a couple of drill presses that have a quill lock which fixes it in place. I am not familiar with your machine, but this may be an issue.
It may be a large wing type nut on the shaft that the handle is on.
It is also possible that the quill is jammed. There is a small gear on the shaft that the handles rotate that fits on a rack type gear that moves the quill.
This could happen if the quill is all the way down and passed the gear.
It is also possible that this is jammed or has something stuck in it.
Apr 08, 2009 | Drills
Drill press
Release the belts and check if you can turn the chuck by habd, if the chuck won;t turn, two things could be wrong, 1) the quill bearings are bad or 2) the shaft that runs down thru the quill could ve rusted causing a restriction, if that's the case, WD 40 should loosen it.
Oct 24, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Drill Presses Features
You compare the following features: Horsepower (HP) is the maximum power produced by the motor. Higher horsepower allows you to bore larger holes through tougher material. Drill presses are available with motors from 1/4 to 1 HP. Size/center drilling capacity is determined by the distance from the center of the chuck to the column. Since the press can bore a hole in a circle with a diameter two times the distance from the center of the chuck to the column, the size is listed as twice the distance from the column to the center of the chuck. A 16" drill press can drill a hole up to 8" from the edge of a straight board or at the center of a 16" diameter circle. Variable speeds allow you to drill different diameter holes through different materials without damaging the material or drill bits. Drill presses are available with five to twelve speed settings. The more speed settings, the more versatile the drill press. The table on most drill presses can be raised and lowered along the entire length of the column. It can also swivel 360° around the column for boring oddly shaped pieces. Better presses have large, tilting tables with fences. Quill travel determines the depth to which the press can bore holes. Greater quill travel allows you to bore deeper holes. Depth-stops control the depth to which the quill descends and limit the depth of the hole. Depth-stops are good for repetitive boring and dowel holes. The more precise your depth-stops, the more accurate your boring operations.
Aug 27, 2008 | Makita 6825 Factory Reconditioned Drywall...
Makita 6825 Factory Reconditioned Drywall Screwdriver Logo
576 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
