Question about Brother MFC-230c Printer
IT IS A BROTHER MFC235C AND THE DISPLAY KEEPS SAYING NO CARTRIDGE, INSTALL BLACK AND OTHER COLOURS LOW. THEY ARE ALL NEW BROTHER CARTRIDGES. PLEASE HELP IM READY TO THROW IT OUT THE WINDOW
  • 666 Answers
You need to go into the menu and reset the error count this tells the printer the print cartridge has been changed otherwise it does not know
hope this helps
Robb
please leave feedback
Posted on Apr 26, 2010
I have a Brother DCP-165C printer. It will not let me clean..it keeps saying "can not detect black " . I've replaced the black cartridge ,but it still says "cannot detect" and will...
Hi
The brother printer's cartridges do not have smart chip hence its a mechanical problem in the cartridge hence remove all the cartridges and inspect with a spot light in the cavity where you install the cartridges there may be something causing the sensor to malfunction. And at the same time try to shake the cartridge a little and then install back slowly as there is a lever which is present in the front portion of the cartridge and this what the printer looks for.
DO RATE MY SOLUTION
Jun 30, 2011 | Brother DCP 165C Compact Color Inkjet...
I have a Brother MFC-7440N machine. On 7/22/10
The toner cartridges have a small port on the side that the printer uses to check the toner level. Our 7440N tells us it will soon need a new toner cartridge and will then print another 400 copies. Search YouTube for Brother Toner Cartridge and it will show you how to modify the cartridge by covering up the portholes with tape. Since there is obviously some kind of sensor, you might need to get a can of air and clean out any extra toner. Lastly, the Brother cartridges have "reset gears" which are replaced when the cartridges are refilled. You might have a cartridge which the gears were not replaced on.
Jul 26, 2010 | Brother MFC-7440N Laser Printer
Hp black cartiedge is low on immediately
When you refill a cartridge, the printer will keep warning you that it is empty- a message pops out that says "low ink". That is because the printer sees the cartridge by it's serial number. The printer can't know that you have refilled the cartridge, so it keeps saying that it is empty. Once you put in a new cartridge, it will display the cartridge as full again.
May 02, 2010 | HP Easy Refill Kit for (HP) Black Inkjet...
The black cartridge on my brother MF-465cn has been replaced but it still won't print black. other colours are fine. The Brother tech guys walked me through a deep cleaning - did nothing. Is this the black...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 16, 2010 | Brother MFC-465CN InkJet Printer
INK CARTRIDGES ALL NEW. SAYING THEY ARE EMPTY
Hi, i think during the process of changing the cartridges, the top lid on the ink cartridge that clips or keys the cartridge down inside the printer has been broken and needs to be replaced.
I suggest you get a technician to help get a replacement for this. With this your printer should be in other.
Jan 04, 2010 | Brother MFC 240C All-In-One InkJet Printer
We recently bought new ink cartridges for our brother mfc-240 printer. It keeps saying no cartridge wether we put the new or old black one in. Is this fixable? -Rebecca
The machine most likely want you to change one (or more) of the other cartridges too. By opening the top cover and reading the display when it is opened, you should get an error indicating which cartridge to change, it most likely isn't the black one it is alarming about, but rather one of the not-changed ones.
Jun 03, 2009 | Brother MFC 240C All-In-One InkJet Printer
When I replace the cyan cartridge with a new one I keep getting the message"No Cartridge"
hi!!! in that kind of problem maybe the sensor of the cartridge was damage thats why the sensor cannot detect when you install the cartridge. Try another cartridge or maybe try the to re-install old one if the printer detect the old cartridge that means the new cartridge was defective. Thanks
May 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
Black ink cartridge doesn't work.
Have you tried
  1. Taking out all the cartridges
  2. Power down the power
  3. Power up the printer
  4. Open the scanner Cover
  5. Close the scanner cover
  6. Message will ask you to put the ink.
  7. Put in Black
  8. Close scanner cover
  9. It may ask you whether the Black is being changed.
  10. Open the cover.
  11. Install Cyan.
  12. Repeat step 8-10 for the rest of the 2 colours.
  13. It should resolve the Black ink empty message.
Let us know if this works.
Thank you.
Dec 11, 2008 | Brother DCP-110C All-In-One InkJet Printer
Changed blk ink cartridge and it says NO CARTRIDGE
see/search brother faQ:
http://www.brother-usa.com/FAQs/faq.aspx?Model=990&ProductGroup=5
Nov 09, 2007 | Brother Multi-Function Center MFC-3360c...
Re install ink
I know this is a dumb question but did you remove the tape off he bottom of the ink cartridge? Also sometimes if you are using a generic ink cartridge the machine may not recognize it. Make sure the cartridge is seated in properly and that it is in the correct location. (not color spot). Hope this helps. John
Sep 07, 2007 | Brother IntelliFAX 1940CN Plain Paper...
Brother MFC-230c Printer Logo
650 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
