Question about Skull Candy HESH Consumer Headphones
No sound come out of right side - Skull Candy HESH Consumer Headphones
  • 185 Answers
Check the jack first sometimes wire breaks at the soldering if it did re-solder it if you can not check it because is not a screw on plug you have to cut it and replace it u can find it at radio shack and if you take it already cut and new plug in hand to a TV repair shop they should charge you about 10 bucks and.............. try not to pull the cable to unplug it, hold the plug and pull.
hope it works
Posted on Apr 26, 2010
It is faulty repair it
Right turn signals are not working
With the ignition on, turn the left turn signal (TS) on and listen for the relay, then try the right side. If the relay sounds on the right side, then check the bulbs on the right side. If the relay does not sound, replace the relay.
Mar 06, 2015 | Cars & Trucks
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
No sound on right side speakers on A&B.Sound does work in test mode. Right side Chanel is working, just no sound on right side front in all input modes. I'm a amateur when it comes to stereos.
Go to "menu/Setup/Speaker level" and adjust the balance of L-R.See page 21 of the manual:
http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v540/?mode=model
Jan 20, 2013 | Yamaha RX-V540 Receiver
Right side no sound to speakers
The output transisters for that side are probally blowin,
Dec 06, 2012 | Technics SA-EX110 Receiver
I have the 2442 fx behringer ''XENYX'' mixing console, and while trying to operate channels 13/14 and 15/16 (these are both stereo channels with mono capabilities, and do not have XLR inputs) I only get...
Check you assign buttons and bottom (three black square buttons) and play with them. It sounds as if you are not sending to that side. You should use mono cables into left and right. I set pan on left all the way left and right, all the way right. Hope this helps.
Jul 06, 2009 | Music
Tv sound only from right side
If you have the wires connected properly for stereo sound, go into the setup for the TV and set it for stereo speakers.
Feb 05, 2009 | Cambridge Soundworks TVWorks 250 Speaker
Click sound front right wheel
replace your right side drive axle b4 it falls out while driving
Jul 14, 2008 | 1994 Honda Accord
No sound from the right speaker
Check the speaker if its okay, disconnect the left side one and connect the right side one and play. If it does not then the speaker is bad.
Jan 11, 2008 | Altec Lansing VS4121 Speaker
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Skull Candy HESH Consumer Headphones Logo
172 people viewed this question
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Owen Barnes
vimal
vimal
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
