Question about Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
What type of oil is inside a diamond submersible sump pump
3 Suggested Answers
  • 257 Answers
SOURCE: we have a submersible sump
A check valve is simply a one way flap, or a ball that rolls forward to let water flow in one direction. My guess is if it's making noise, either the pump is not producing an even pressure or the line is not properly secured and is hitting inside a wall. Make sure the line has straps every 3 foot and at any bends.
Posted on Mar 14, 2011
SOURCE: oil for submersible sump/effluent pump
I have a master plumber 1/3 HP model 539892 submersible effluent pump and was wondering if it takes oil and if it does what type of oil.
Posted on Apr 03, 2011
Sump pump runs constantly
external float type? move float up and down- should shut off if down - if not - switch needs to be replaced
Dec 22, 2013 | Liberty Pumps 253 1/3 hp Cast Iron...
We have a submersible sump pump and a check valve in the line and everytime it goes off we get this thumping noise. Could it be a bad check valve?
Feb 19, 2011 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
Pumb only pumps a small amount out of the basin. Float needs adjusting to go all the way down and empty the basin. How do you adjust the float/bulb to travel farther down without shutting off after only a...
Flotec website shows several submersible sump pumps, and pump types:
http://www.flotecpump.com/asp/productapplication.asp?AId=28
Click product, then click on 'parts and literature' to access manual
Here is a Flotec manual:
http://www.flotecpump.com/pdf/FP525%2811-1-06%29.PDF
Manual for this type of sump pump says:
Quote from manual: Automatic float switch is sealed and factory adjusted for
most home sumps. Turn-on water level is 10" - 12" above
pump base. Turn-off water level is 4" - 6".
The manual also says that running the pump when dry will ruin the seals.
This implies that the water level setting is set so the seals will not be damaged
You might be able to dig the sump deeper, but I don't know if that meets your objective.
Oct 24, 2010 | Flotec FP0S2400A-03 1/3 HP 2,500 GPH...
How do you add oil to a sump pump? Do you add it to the water in the pit?
dont add oil to water-- if u have to or want to oil motor get a spray lube unplug unit and at bottom remove debris guard only clips on and spray shaft and behind impeller if need to lube upper motor bearing unscrew housing and carefully pull up enough to lube top of motor replace housing careful of watertight seals and test pump oil poured into pit would only be pumped out and does not contact motor which sits in watertight housing
Jan 25, 2010 | Little Giant Submersible Sump Pump, 1/4 Hp
Oil for submersible sump/effluent pump
Jul 20, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
What oil is inside a 1/3 HP 1725 RPM effluent pump
You can refill it with capella oil. This is the same as the oil used in refrigerator compressors, and be acquired
from stores specializing in refrigeration and airconditioning. Send us an e-mail for further assistance.
Jun 29, 2009 | Submersible Systems Submersible Sump...
Oil type
these pumps are supposed to be sealed and not to be able to oil,,
Jun 28, 2009 | Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP
What kind of oil do you put in a tsc130 wayne sump pump
The seal is bad and adding new oil will not fix that problem. If you get the seal fixed, normally you use 20 wt non-detergent oil in submersible pumps.
Jun 27, 2009 | Plumbing
I HAVE A 8 1/2 DIAMETER SUMP.MY OLD PUMP FAILED. CANNOT FIND A PUMP SMALL ENOUGH TO FIT.HELP!
get a submersible zoeller sump pump the flaot is attached to the pump not a teather and it wilol keep less water in the pit,, this is the best pump on the market
Jun 12, 2009 | Zoeller M211 Automatic Aqua-Mate...
Water ACE SUBMERSIBLE SUMP PUMP 1/3 HP Logo
65 people viewed this question
Top Water Electrical Supplies Experts
Lawrence Oravetz
Ottoniel
Are you a Water Electrical Supply Expert? Answer questions, earn points and help others
