Lands Phones Logo
Posted on Apr 26, 2010
I lost my car charger fo a uniden modellrd6100swswere can i replace it
Where can i buy a replacement uniden charger station for bb40152616
Hello John Zuraw,
Your QUESTION... Under "Lands Phones"
"Where can i buy a replacement uniden charger station for bb40152616"
The number "bb40152616" is resonating with
ABSOLUTELY nothing on a GLOBAL SEARCH...
Here in the USA Uniden has Customer support at
Uniden Cordless Phones Headsets Marine Radios Radio Scanners at udn...
or ... Call them! (844) 880-5111 They are available 24/7
ELSE
A wireless remote model number for a UNIDEN phone
ought look like "TCX905"... (2 line)
Likewise amateur radio ...scanners.. 2 & 10 meter
amateur radios (etc.):
USE eBay "top rated" seller(but watch out for those shipping costs);.
Try your search here:
0results for uniden bb40152616
Hope this helps...
Carnac the Magnificent
Lost recharger for model # GMR5089
You should be able to order a replacement on line.
1helpful
My Uniden phone will not charge up, even when it is on the charger it says, set on charger, battery low.
First open the handset and disconnect the battery. Then reconnect the battery (just in case the connection is loose). Make sure that the battery is in the handset in the correct orientation.
How old is the battery in the handset? After a year (frequently), the battery must be replaced. This time includes the length of time the battery was in storage before you received it. If you add a comment with the model of the Uniden phone, I will be glad to provide additional information on the cost of the replacement.
If the battery is new, then the charger may have failed. (I have seen this with many rechargeable devices.) Make sure the contacts are clean. However you may need to replace the charger. Again I need the model number to check if additional handsets are still available for the phone.
If your phone is under warranty, contact Uniden for repair/replacement of either the battery or the charger, as needed. Start at http://www.uniden.com .
I hope this helps.
9helpful
4answers
I lost the owners manual how do you put is a list fo names and phone no.
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Where can I buy an A/C charger for my Uniden Atlantis handheld marine radio? I lost mine.
Your power cord and charging cradle are not listed as available accessories. I suggest you follow the link below and send a query directly to the Uniden customer service center.
http://www.mycusthelp.com/uniden/
Lost charger for aqtlantis 250. If i go to radio shack what do i ask for? THANKS. TOM
Charger - Cradle for Uniden Atlantis 250 - Uniden Part # GCAS3B3640Z (Cradle Only - No adaptor)
Hope this helped.
2helpful
UNIDEN cordless charger for india
UNIDEN DOES NOT SUPPORT SERVICE IN INDIA, TRU 9466/TRU9485 WILL ONLY WORK IN THE US AND CANADA. USING ANOTHER CHARGER COULD DAMAGE THE BASE.
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
