Question about Frigidaire FMV156D Microwave Oven
I have a Frigidaire Microwave oven CFMV156DBA. The clock, lights and the keypad works. The turntable does not turn and it does not heat
  • Frigidaire Master
  • 9,047 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Apr 28, 2010
Frigidaire Gallery Microwave making a new
If this is new, return to the place of purchase, causes, defective magnetron, bad inverter board, and possibly keypad control board.
May 20, 2012 | Frigidaire FGMV185K Microwave Oven
GE Microwave Model: JVM1540DN1BB Keypad appears to work... but Microwave doesn't work
The problem is more than likely in the microprocessor control board, sometimes a bad relay, or poor solder points.
Mar 11, 2012 | Microwave Ovens
Microwave does not come on.....but when i hold up oven door a little it comes on.
Frigidaire microwave FMV156DSB. Turntable don't turn and no heat. Clock, keypad, light and fan works. The guys above looks like they right about either the door or the switches for the latch. This model does have two switches and a fusible switch. Pushing up a bit on the oven door from the bottom right corner when its closed make mine turn on if you set it to cook. Switches numbered 8(x2) on the schematic has part number 5304440026 $18.05. Fusible switch has part number 5303319559 $30.36. Have'nt changed them because it may be the door hinge is bent since the door latch is made out of plastic. Also looks like a real pain to take apart just to get to the switches. I will try to bend the door hinge to see if it fixes it. "And..now." -- Kirk, "Huh?" -- Scotty, "The doors, Mr. Scott." --Kirk, "Aye. I'm workin' on 'em."
Mar 11, 2011 | Frigidaire FMV156D Microwave Oven
My Pro Series Frigidaire Microweave oven is not heating. The turntable is not turning but the light is working and the timer is counting down.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 10, 2011 | Frigidaire PLMB209DC Microwave Oven
FMV 156DSB Timer and light works, but does not heat unless you push up on bottom of door.
Slacken off the lower hinge screws and re set the door to the correct height, then tighten them back up.
That should sort that out.
Jan 02, 2011 | Frigidaire FMV156D Microwave Oven
Won't heat and turntable doesn't turn
In all likelihood the mangnetron has failed, or perhaps even something in the Power Supply. or a fault that is shutting the system mangnetron down, for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Jan 31, 2010 | Frigidaire FMV156DC Microwave Oven
The keypad and clock works but the oven will not heat. and the oven makes a loud, abnormal sound when turned on. any ideas how i might get this oven running again?
If it appears to be making all the normal sounds but just a louder noise and no heat, your probably looking at a magnetron that is bad on unit. You are looking at about $100 just for the part. Hope this helps
Dec 02, 2009 | Frigidaire PLMV169DC Microwave Oven
Microwave oven does not heat anything. Clock, turntable, lights work. I turned the turntable off while the oven was cooking--heard a noise, now it doesn't heat anything.
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Jul 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works...Except for actually heating the food
It has a bad magnetron. This is the tube that provides the microwaves to heat the food. Not too easy to replace yourself but it can be done. Cost of magnetron is probably less than $50 or $60.
Dec 14, 2007 | Frigidaire PLMV168 Microwave Oven
Frigidaire FMV156D Microwave Oven Logo
522 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
