Question about Epson Stylus R290 InkJet Printer
May r290 printer is not working its showing cartidge and paper error and doing nothing..its blinks again and again
  • 622 Answers
Check the link below to see which error code you have link http://www.refillbros.com/en/manuals/p1085-epson-stylus-photo-r280-r285-r290-service-manual?page=30
Posted on Apr 26, 2010
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
also
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
I did head cleaning many times but my Epson R290 is showing error at YELLOW. I replaced ink, still showing the same.
Posted on Oct 26, 2010
After years of using the same setup I get a communication error on my Epson r290.
Sounds like you have multiple drivers. On the MAC, go to the printer set up window in system preferences and select the r290, then go to the "-" minus icon at the bottom to dump the r290 from the list. Restart the computer with the r290 connected and see if the system recognizes it again in the preferences window. Hit the + icon to add it. Hope this helps.
Sep 04, 2014 | Epson Stylus R290 InkJet Printer
I have general error in my r290. its stop working. i have done restater but its not working so what i do.
sir my printer is r29o.i d every thind.reset.right nd left.but double is there plz help me.
Jul 17, 2011 | Epson Stylus Photo R320 InkJet Printer
Nothing prints out on paper
This could be from a dried print head. I have had this before. I fix mine by taking a paper towel folding it up a few times and then putting some rubbing alcohol on it then I take the ink cartridge and rest them on it till I see the ink start flowing again. Hope this helps.
Mar 08, 2009 | HP PSC 1510 All-In-One InkJet Printer
Epson r290 printer no printing now
try to clean yellow nozzle manualy, use a spuit and flexible pipa (as in cleaning mechanism), use a cleaner.
Feb 21, 2009 | Epson Stylus R290 InkJet Printer
Check paper tray check cartidge.
I have the 1350 all in one, and when I changed my cartridges I screwed up and replaced both at the same time, that was a no no as I found out. I kept getting the test printer and print example too. so what I had to do was Uninstall the printer and drivers, then reinstall them again, that worked.
Oct 28, 2008 | HP LaserJet 3015 All-In-One Printer
Error code E-90
When turning on the power, the Carriage
Unit collides to the Change Lever
located to the front side of the printer. CAUSE
PF Motor
Ink System
CR Scale
CR Encoder Board
Holder Shaft Unit
OR IT S SAMPLE JUST WHEN YOU OPEN THE SCANNER TRY TO MOVE THE CARRIAGE BY THE GEAR OR SOME PAPER JAME IT DO THIS PROBLEM.
Oct 22, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Epson Stylus R290 InkJet Printer Logo
533 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
