I have a hp 2335 monitor. Every so often the pip displays in the top-right corner of my screen. Pressing the pip button sometimes removes it, but I want it to stop appearing altogether. How do I do this?
    Problem Solver:
  • 10 Answers
OK, I think I've got this fixed for mine now. Go to the OSD menu, Video Input Controls, PiP Control, PiP Size, and select PiP OFF. I think I must have been getting noise on the composite video input that was causing the PiP field to display sometimes.
Posted on Sep 28, 2010
How do you get screen full size. Picture is in top corner
Could be PIP (picture in picture) has been accidentally switched on.
Accidentally pressing the PIP button on the remote is something I used to do regularly.
Sep 09, 2017 | Televison & Video
How can i adjust horazantal and vertical screen monitor size so i may fill full screen?
In Windows:
1) Click the "Start" button lower left hand corner of the screen, or the Windows key on the keyboard,
2) Choose "Control Panel",
3) Choose "Display"
4) Choose "Change Resolution", and select one that gets you where you want.
FixedYa !
Feb 25, 2015 | HP Desk Top Access Center DK985A
Panasonic p50u20b - picture shrunk into top right hand corner of screen
seems you have found the PiP (Picture in Picture) if you still have the orignal remote press the pip button or the cancel button
Dec 28, 2011 | Panasonic Televison & Video
Can anyone offer any suggestions on how to delete/remove titles displaying in the upper left hand corner of my TV screen and right hand corner? For example, if I am watching a program on CITY, the title...
I believe the "Caption Vision" is selected. By pressing the "Display" button on the remote it should toggle through the choices until "Display Off" appears. That should be all.
Mar 05, 2011 | Sony KV-32S42 32" TV
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
When i mouse over the top left of the screen.. about a line of pixels go into a crazy assortment of colors in a line at the top of the screen. It only does it in the top left corner... I just opened...
try to adjust your computer's display setting, sometimes improper display settings causes that.
Another area to look is to see if you have any "Hot Keys" setup for that corner. Sometimes those corners are setup as shortcut key for doing something. You might have it set without actually knowing.
Aug 23, 2010 | HP Computers & Internet
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
HP 2335 Monitor - Blank area upper 1st quadrant of screen
Press the PIP (picture in picture) button once again. It is the leftmost of the front buttons below the panel, opposite the on/off switch.
Nov 16, 2009 | HP Computers & Internet
Channel displaying on Samsung 32"LCD TV
Most remote controls have a "display" button. Pressing that is what gets that channel number on the screen. Try pressing it again and the display should turn off. On some brands the display may cycle through various combinations (channel number only, channell and time, etc.) before it goes away, so it may take more than one press of the button.
Dec 03, 2008 | Samsung 32 in. LCD Monitor TV
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
