Question about Brother MFC 240C All-In-One InkJet Printer
I understand I can use my fax mfc 240 with my
I understand I can use my fax mfc 240 with my internet phone . How do I hook it up
  • 4,041 Answers
Hi There
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
Click LINK= http://www.4all2sell.com/pdf/Brother-MFC-240C-Manual.pdf
You will need a adobe reader to see this file If you not got an PDF reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
I have a brother mfc 6800 and do I need a telephone line on it?
You will need a phone line connected to the MFC 6800. If you have a separate line for your fax number, make sure you connect this line to your MFC 6800. If you have a different ring, but on the same line as your phone number, you'll need to set up your MFC to utilize the distinctive ring (see the manual for setting this up).
Jan 26, 2010 | Computers & Internet
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Brother MFC-240 will not receive faxes...
I cant get my MFC-290 to receive incoming faxes
Sep 21, 2009 | Brother Multi-Function Center MFC-240C...
Faxing problem with mfc-240. Faxing sallie mae getting busy no response this is bull. They have a fax server. Whats up?
hi
check ur phone line conections and if it is connected to the right port and if u need our technician support contact http://tinyurl.com/mtgjzz
Jun 22, 2009 | Brother DCP 130C All-In-One InkJet Printer
Don't know how to connect
Hi, I'd love to help you with the problem you described.
  1. Connect your phone line (out of the wall or your phone modem supplied by your phone or cable company) into the jack on your MFC-240 has a picture that is shaped like a little telephone. These jacks are located on the lower left back corner when you are facing your printer.
  2. In the same location, there is another jack right next to the one you just plugged into. Take the phone cord that came with your printer and plug one end into the jack.
  3. Plug the other end of this cord into the base of your phone or answering machine.
  4. Test your connections by picking up your phone handset and listening for a dial tone.
  5. Next, set the receive mode your printer for fax only (if you set the receive mode to phone/fax or other mode, you could experience problems with your voice mail). Fax only will ensure that your printer will only answer fax calls. Here's how you do it.
Here's how:
  • Press the menu key on your MFC-240
  • Press 0 (display switches to initial set up)
  • Press 1 (display switches to receive mode)
  • Fax only should be the first item that shows on the display.
  • Press the ok button on your MFC-240. The machine is now ready to receive faxes.
If you have not done so already set up either your answering machine or your cable company voice mail.
If you found my answer to be helpful, please use our rating system to indicate your level of satifaction with my answer. Thanks for using FixYa!
Jan 28, 2009 | Brother Multi-Function Center MFC-240C...
CAN'T GET FAX WORKING.
If it's answering on your main number, then you are not plugged into the fax jack. You should have a separate phone jack for fax. If you have internet phone there should be a second jack on the back of your phone box. You can test that you have a functioning second line by plugging the fax into it and using the fax unit to dial your home number.
Jan 05, 2009 | Dell 926 All-In-One InkJet Printer
How do I hook up my fax on my
Only way to use internet and fax simultaneously is to get DSL
Nov 01, 2008 | Brother MultiFunction Center MFC-440CN...
Brother mfc 240-c
How do i mirror an image on brother mfc 240
May 30, 2008 | Brother MFC-7820N Laser Printer
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Mfc 240 c
Did you do a firmware update? If not go to brother homepage , download the update tool and do the update if it is avaiable.
Do you print with generic ink? If yes this prob is because of different color depth. Try to print with the original innobella ones or do some resettings within the printers properties when you print a pic from pc.
You may test the print out by printing directly from a picture card without pc.
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 240C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
