Question about PC Chips M863G V3.0C W 3400+ (ATHLON 2600 MHZ) 166MHZ FSB W FAN (M863GV30W3400) Motherboard
HOW TO SPEED UP THE FAN SPEED TO IMPROVE SPEED OF SYSTEM
  • 119 Answers
Check the BIOS. Some motherboards allow you to regulate the CPU speed. Just look under Power or Advanced settings.
Posted on Apr 26, 2010
How do you speed up acer aspire one zg5 aoa110
If you want to get the thing done quickly, it is recommended to use an Acer speed up software. Learn more here: http://www.speedupacer.com/
Jan 13, 2012 | Acer Aspire One AOA110-1113 Netbook
Very slow speed on my 9301 laptop
You can speed up your 93011 laptop by:
-- cleaning system junk
-- optimizing computer services
-- optimizing internet
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
May 23, 2011 | Acer Aspire One PC Notebook
System performance is degrading
first of all you do need to format your PC to improve system speed.system speed degrades because of viruses or temp files in your pc.so we will delete all those
1.Click on start->run and type %temp% and delete all the files
2.scan your pc with Malwarebytes Anti-Malware - Free software downloads and software reviews - CNET Download.com
This will remove all the malware on your pc
if you still want to format,you need to back up all the files in drive c: where you windows is installed
Jul 31, 2010 | Sony Computers & Internet
Motor fan is extremely loud!!
It is likely your fan clutch has gone bad and needs to be replaced.
Fan clutches are engineered to improve the vehicle’s cooling system efficiency. The clutch engages the fan at low speeds when additional cooling is needed. At high speeds the clutch disengages the fan, removing the load against the engine and allowing the engine to run more efficiently.
There are two types of fan clutches, non-thermal and thermal. Non-thermal fan clutches engage the fan based on the shaft speed of the water pump. Thermal fan clutches engage the fan based on a bi-metal thermostatic coil, which senses the under hood temperature.
It will look like this...
Apr 02, 2010 | 1995 Lincoln Town Car
No heat in the front and rear of the truck but the
No engine water is getting into the mini radiators. You could attempt an engine flush to clear out debris... or have it done professionally. A failed temperature control is a possibility - but clogged cooling system is MUCH more probable.
Flush TWICE, with new radiator flush each time.
Be sure the heater is on max temp with decent fan speed. Run for 30 minutes on each load.
Then clean water,
Then 50-50 mix of antifreeze and water... If it was clogged, that will improve it greatly!!
If not, you need the cleaning anyway... then the temperature switch can be addressed.
Nov 23, 2009 | 2000 Ford Expedition
I lost the driver
It does not look like it burns CDs. Here is the Features of the LTN-486S.
  • 48x CD-ROM with Pure-CAV Technology.
  • E-IDE Interface, support all PIO, MW-DMA, Ultra DMA-33 modes.
  • Support Power Saving Function.
  • Support High Speed Digital Audio Extraction ( DAE ).
  • Support High Speed VCD Data Extraction.
  • Support Plug & Play; Emergency Manual Eject.
  • High Speed CD-Audio Playback Technology to Improve Audio Playability.
  • Access all format CD, CD-R, CD-RW Title & Disc ( support up to 99 mins ).Easy-TrayR Design for both horizontally & vertically use.
  • Gear-Driven Tray Loading Mechanism to improve reliability.ABS Auto Balance System ( 486, 485 ) Mecha to Reduce Vibration R Noise.
  • WSSR Wire Suspension System ( 483 ) Mecha to Reduce Vibration & Noise.
  • Jul 01, 2009 | Lite On (LTN486S) Internal 48x CD-ROM...
    Slow condenser and evaporator fans on SDL20KCSABS
    Newer GE refrigerators use variable speed DC fan motors to improve energy efficiency. Fan speed is determined by the electronic control board. Your refrig is working as designed.
    Please don't rate solution, as anything but a Fix-Ya lowers my overall score. Thanks.
    Mar 03, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
    Speed so slow internet of no use to me!
    by doing two simple steps u can improve your speed
    1)delete all temp files in yor system
    2)give clear cache every day..at any time u wana test your interenet speed reach here http://www.ip-details.com/internet-speed-test/
    Jan 27, 2009 | Computers & Internet
    My E-Machine model #T5082 seems to run loudly at times. I there any way I can make it more quiet.
    If you are acquiainted and well educated with BIOS settings, try decreasing the hard drive speed or fan speed...
    Kindly give a feed back to Improve and to see If it was helpful for you...
    Thanks and Regards
    Mar 28, 2008 | Computers & Internet
    Improve laptop performance
    it is not actually recommended to change the processor or the board of laptop. the only way you can improve the performance of it is to add extra memory and constant system maintenance and clean up, also avoid installing unnecessary programs. this is the safest way in improving your system.
    Feb 09, 2008 | Toshiba Tecra M1 Notebook
    PC Chips M863G V3.0C W 3400+ (ATHLON 2600 MHZ) 166MHZ FSB W FAN (M863GV30W3400) Motherboard Logo
    Top PC Chips Computers & Internet Experts
    David
    David
    Steven Burn
    Steven Burn
    Jerry Umali
    Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
