Question about Campbell Hausfeld Electric Pressure Washer 1800 Psi
Campbell Hausfeld pressure washer 1750 PW1 1.8 GPM unit on/off switch doesn't work
5 Suggested Answers
comax
  • 154 Answers
SOURCE: Does anyone know what the spark plug gap setting
Most gas engines will work fine at .030 to .035 sparkplug gap
Posted on Apr 16, 2009
  • 770 Answers
SOURCE: My 1750 psi campbell hausfeld pressure washer will
Common with that washer...it has a wabble pump. Release the trigger, if by pass does not engage, stalls engine. You can however keep using it, all you have to do is keep trigger pressed, and when you are cranking engine, depress trigger with the free hand. Can be repaired, but the fix probably will cost more than a new pump.
Posted on Oct 19, 2009
  • 251 Answers
SOURCE: pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
the unloader valve is deffective , this has a small metal rod which activates a microswitch to turn the machine off , replace the unloader valve
Posted on Nov 19, 2009
SOURCE: What kind of oil do
The pump uses SAE20 or SAE 30 non-detergent motor oil that fills up about half way
The engine uses 10-W30 motor oil that comes a bit more than half-way up dip stick.
Do not turn washer on its side or upside down to drain oil, or oil will run into carburetor.
If you have problems starting:
read:
http://www.fixya.com/support/t6504468-craftsman_2700_psi_pressure_washer
Posted on Nov 09, 2010
Oil leak under machine, how do you tell if pump needs more oil
Oil is leaking from the engine. Pump does not have oil in it.
Sep 01, 2016 | Campbell Hausfeld 2500 Psi, 2.4 Gpm,...
How much oil and gas mixture to use in 1800 psi 2.2 gpm washer where do i put in the oil
it is a 4 stroke motor so it just runs on neat unleaded fuel.
oil is in the engine and this should be 30w oil
Jun 18, 2011 | Campbell Hausfeld PW2102 Gas Pressure...
Solutions won't feed from bottles on machine? I use the switch on this machine to use a deck cleaning solution and the bottles won't feed the solution into the water.
I have a SIMONIZ S2000 electric. I bought the unit about 8 weeks ago used it once. On the second use yesterday the unit didn't work as well, the pressure seemed only a bit better than hose pressure and soap did not dispense at any pressure. SO.... after much thought I turned the hose/tap pressure down so that I only got about 2-3 GPM instead of the typical 5-6GPM normally coming out of my hose....... it worked! Soap dispenses and spay is way better! It seems that if if the inlet hose pressure is high the pump doesn't work as well... go figure.
Jun 25, 2010 | Campbell Hausfeld 1800 PSI Electric...
Gun
Replace the wand (Gun) The valve is not repairable.
Jun 16, 2010 | Campbell Hausfeld PW1750 Electric Pressure...
Pulsing Campbell Hausfeld 1300 psi 1.6 gallon electric
Nov 18, 2009 | Campbell Hausfeld 1,350 Psi Electric...
C/H 1750 Washer will not start with water connected. Electric motor will start without water connected.
HI I would think that your pressure switch has stuck.
You will need to remove the covers etc and check the internal pressure switch that will be situated on the outlet of the pump. It maybe stuck and just want greasing etc or may need replaceing.
Oct 30, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Stops running after a few min. of spraying and won't start up . campbell hausfeld 1300 pressure washer
hi sounds like the rong nozzel in the lance and it's pulling to many amps so it overloading the motor and tripping out, take the lance off then try regards
Oct 25, 2009 | Campbell Hausfeld Tools 1300 Psi X 1.4 Gpm...
Campbell Hausfeld 1750 Pressure Washer Won't Start
throw it away seems to be the only solution since no one has a clue in what there talking about, nothing froze always cleaned out system and still wont start, campbell hausfeld does not have a clue neither, they told me you got to check this one out, drop unit about a foot off the ground and yea i tried it about 8 times then almost threw it across the yard, oh well i hate being negative and love to fix whats broke but the hours spent i could be making money and just buy another, thank you
Feb 26, 2009 | Garden
Campbell Hausfeld Electric Pressure Washer 1800 Psi Logo
315 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Tim Venetis
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
