Question about Samsung RB1955 Bottom Freezer Refrigerator
The temp control read -14 and 34. The actual temp is about 9 /50
If I unplug the unti the compressor will kick on and bring evrything to the right temp. but the compressor will not come on by itself.
  • 3 more comments
  • rucketeer Apr 26, 2010
    Oh sorry,
    it is RB1955sh
    Oh sorry,
    It is RB1955sh
  • rucketeer Apr 27, 2010
    Do you reccomend I order the part before performing the rest of the instructions?
  • rucketeer Apr 28, 2010
    So...
    I did this and the buzzer and compressor came on when the test button was pressed. the buzzer did not turn off. after about 15 min of this i unpluged it and plugged it back in again. the buzzing stopped the compressor came on, but i noticed that the compressor still never engaged on its own later.....
    Also, during the test the panel read FF on the freezer side and the fridge temp on that side.
    And these are in the Refrigerator and the freezer?
    President:
  • 1,554 Answers
The compressor relay fails to reactivate due to a faulty MICOM IC or a failed sensor. An open sensor makes the MICOM "think" that there's an extremely low temperature and will send power to the relay to activate it. Perform the forced operation when the compressor turns off to check if it can be activated.
Disconnect power to the appliance and remove the screws securing the compartment cover to the rear bottom access panel then slide it up and take it off.
Facing the rear of the refrigerator, remove the cover of the electric box located to the right side of the compartment. With the cover removed, reconnect power to the refrigerator to run the compressor and when it stops, carefully press the test button on the control board located below the capacitor on the left of the heat sink. The buzzer will sound to indicate the forced running is activated and the compressor will run.
Replace the control board (part number DA41-00128D) if the compressor doesn't run during the forced running activation. it is recommended to include replacing the sensors as a preventive measure.
Posted on Apr 27, 2010
  • 4 more comments
  • Jahn27
    Jahn27 Apr 27, 2010
    Note: The service guide given is intended only for someone with adequate background in electrical and electronics servicing and repair.
  • Jahn27
    Jahn27 Apr 27, 2010
    Perform first the given instructions before ordering the part.
  • Jahn27
    Jahn27 Apr 27, 2010
    Feel free to update me about the result of the test.
  • Jahn27
    Jahn27 Apr 28, 2010
    "The compressor relay fails to reactivate due to a faulty MICOM IC or a failed sensor. An open sensor makes the MICOM
    NOTsend power
  • Jahn27
    Jahn27 Apr 28, 2010
    The problem is not within the control board but in any of the freezer and refrigerator sensor. Replace both sensors in the freezer and refrigerator compartments including the defrost sensors.
  • Jahn27
    Jahn27 Apr 28, 2010
    The freezer sensors are located on the freezer evaporator with part numbers DA47-00095E and DA32-00006W while the refrigerator sensors are located on the refrigerator evaporator and evaporator cover with part numbers DA32-00006W, DA47-00095E, and DA32-10105T.
  • 15,935 Answers
What is the model # of the unit please??
Thanks!!
Posted on Apr 26, 2010
Why does my upright freezer runs then kicks off, runs then kicks off?
Good Afternoon Friend,
I understand your Frigidaire freezer runs for a short time and then kicks off. Then it turns on with a click and repeats its cycle. This is how your freezer functions. When it needs to cool, the compressor will kick on and cool until the temperature is reached. Then it will kick off until it needs to cool again. It's possibly due to the hot and humid summer that it is cycling on and of more. I hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Freezers
Samsung rm255lash is not getting cold and freezing
If the compressor runs it's not a control fault. It all points to a refrigerant leak
Jul 02, 2012 | Samsung RM255LASH Side by Side...
My Amana TX18QL is not working properly. The freezer temp is too high about 26 degrees and the refrigerator is about 60. The temp controls are set to max. For quite some time water would come out or the...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 04, 2011 | Amana Refrigerators
Wireing
Temp fan failure could be the thermo temperature sensor. I am not sure of the actual name of it but if you can direct wire your fan and it works, then the fan is good, the sensor is bad. I myself have rewired a switch to them so I can control when and how long the electric fan runs.
Apr 06, 2010 | 1996 Chevrolet Monte Carlo
I changed the air compressor and the dashboard control panel last year and it has done ok. Now the temp. fan and the compressor fan won't kick in and the air compressor won't kick in also. Checked all...
You say temp fan?If you mean the cooling fans,then the ac is out of freon most likely,the freon has to be in the system,and enough to kick the compressor on,therefore turning the cooling fan on.
Air conditioner clutch will not engage. also my car has auto climate control and the external temp. light always reads 30 degrees.
That is why the A/C clutch is not coming on.If the temp is below 50 degrees the auto control will not allow the compressor to kick in to protect the compressor.You have to check the codes for the body control module.It should show a code for the outside temp sensor.You could have a bad sensor or wiring.If you disconnect it it should show -40 degrees.check wiring and connections.Hope this helps.Good luck.
Apr 05, 2010 | 1999 Buick Regal
Oven fails to reach correct operating temperature. Set at 400 = actual 300 temp. Temp probe is clean.
Clean and working correctly are 2 different things.
Unplug the range. Remove the temp sensor. Use a meter set for ohms and read 1050 to 1150 ohms at room temperature.
If it reads OK replace the electronic control. If it reads bad replace the temp sensor.
Jan 04, 2010 | GE Kitchen Ranges
I HAVE A PROBLEM WITH COMPRESSOR NOT KICKING ON
Actually you should check also the thermostat control, if you know how to ypass the thermostat control then do it just to check if your compressor running smoothly, well it should be since it was newly replaced,
well if runs, then your problem is your thermostat, but if not then check your supply current if it is stable or under voltage, if it is fluctuating then better yet put a UPS (un interupted power supply) or AVR (auto voltage regulator for your sensitive appliances cause it might also affect other appliances.
If your electric current is stable, then check the controls of your refrigerator, if it is electronic then try to test it with the service center but if it is manual then try to put starting capacitor for your compressor, it might be hard starting,
hope this will help
Oct 31, 2009 | Refrigerators
The ac compressor runs and cools properly when temp is cool,but on warmer days it will run then kick out and will not kick back in for several hours later.All pressures are good...the freon charge is...
What year is the vehicle ? The A/C button on the control panel is a direct input to the PCM /ECM - engine computer . The PCM/ECM energizes the compressor clutch relay to engage the compressor .
Apr 13, 2017 | Oldsmobile Cutlass Supreme Cars & Trucks
Samsung RB1955 Bottom Freezer Refrigerator Logo
217 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
