I need inverter board - Televison & Video
Toshiba Regza 42RV535U42" LCD HDTV when i turn it
Check the power going to the inverter board (24V) if ok...replace Inverter board....
Oct 28, 2013 | Toshiba Regza 42RV535U 42 in. LCD HDTV
VIZIOP42HDTV10A . It hadn't picture mean black screen , but hear sound from every channel and all another devices input
hi, Your tv has problem with its back light inverter stage. All LCD TV have back light to illuminate the pixels. There are two types of back lighting CCFL(Cold Cathode Fluorescent Lamp) and LED. In your tv its ccfl. As it is ccfl it need a high voltage above 1000v. To provide such a high voltage there will be an inverter stage in all lcd tv with ccfl back lighting. Normally in LCD tvs there will be three boards such as Mother board , Back light inverter board, and power supply. In your tv the ccfl back light inverter stage is faulty. There will in inverter transformers in the inverter board. As it is high voltage transformer there is possibility of its winding get shorted. If so it will drain a high current from the power supply and the protection circuit will shut down the voltage to the inverter board. check the inverter board first. Also there is possibility of bad electrolytic capacitors in the inverter board will lead to this type of problem. First of all check the supply voltage from the power supply to the inverter board. Change the electrolytic capacitors in the inverter board and in the power supply stage. If the problem is not rectified then you have to replace the inverter board. ok
Jun 10, 2011 | Vizio P42HD Television
Screen is totally blank at startup. HDD light blinks for a little bit, but screen stays blank.
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 11, 2010 | Dell Latitude D830 Laptop Computer PC...
Screen is dark
Oct 10, 2010 | Dell Computers & Internet
Thinkpad T20 display is very, very dark (unreadable). Does the display need to be replaced ?
Oct 08, 2010 | IBM ThinkPad T20 2647 Notebook
Compaq nc6000 screen brightness - very dark
Oct 07, 2010 | HP Compaq nc6000 Notebook
The screen is not working it will however run an external monitor jus fine
Diagnosis:
Oct 06, 2010 | Dell Inspiron 1501 Notebook
Replaced cracked display screen with new one and screen is black. System works with external monitor. Is there any drivers that need installed?
Sep 26, 2010 | HP Compaq Presario CQ50-210US Notebook
The screen is white >>>
Your inverter board is OK otherwise you will not get any light on the screen, there is only one inverter board, Check the flat ribbon cable connected to the LCD panel (locate behind the LCD panel), when this connector comes off you will get white screen.
Nov 06, 2009 | Sony VAIO VGN-CR510E/T 14.1" Laptop
Audiovox fpe2705 inverter board replacement
You need to verify first that you do have 24vdc feeding the inverter boards, if you do have 24vdc then we can be sure it is the inverter boards. The inverter board will have very small surface mounted fuses, check for that also.
Dec 27, 2008 | Audiovox FPE3206 32 in. LCD Television
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
