Question about Canon PowerShot S51S Digital Camera
Connecting to my laptop
When I connect to my laptop it says found new hardware and then says it did not install properly. Please help!!!!
    Novelist:
  • 130 Answers
Here are the steps to take.
1. Establish whether or not you have a connection between your camera/computer by going to your start button, control panel, system, hardware tab and device manager. The camera must be powered on and in playback mode (should automatically go to playback mode when connected, camera's screen should go black if there is a connection). Make sure you have a fully or nearly fully charged battery in your camera.
2. Once in device manager, look under Imaging Devices. If your camera is properly connected it should show up as Canon Powershot SD800. If it shows a yellow exclamation point, there is a driver issue, and even if it doesn't show a yellow exclamation point, you may want to update your driver anyway by right clicking and having the system search automatically for driver updates. If download of driver begins, great...once finished, restart camera and your problem may be resolved.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4. If you have any other imaging software running, exit or close the program in your system tray (down by your clock in the right hand corner of your computer's desktop.
5. Try again to connect.
6. If you are on a desktop, try a rear usb port vs. a front port. You can also try a different port on a laptop. After each change, try restarting camera to establish connection.
7. Go to start/My Computer and look for the icon for your camera...you will be able to download images even without Canon software loaded onto computer so this is not a software issue if you have no hardware connection. If you see the icon, right click on it and choose Get or Import pictures. From there the default Microsoft scanner and camera wizard should launch and you will be able to import your images.
8. If still no connection, try going to Start/Run and type in services.msc here you are looking for 4 services to be running. Check under status of each service and make sure it reads that each of these services are started.
  • Canon Camera Access Library 8 (if Canon software loaded)
  • SSDP discovery service
  • Universal Plug and Play Device Host
  • Windows Image Acquisition
Once all of these services are started on your computer, restart camera once again. If any of the last three services are not on your computer or are not started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
MrsJGreen
Posted on May 30, 2008
SOURCE:
Found new hardware but might not work properly is the error shown to me when i am connecting usb drive .in device manager usb is showing with exlamatiom mark in yello
It means Windows can't find a driver match for the device. It's trying to use a generic file, and it may or may not work properly.
The best thing to do is use your device's installation CD, or download a specific driver for it (for the version of Windows you're using) from the manufacturer's website.
Hope that's helpful.
Jan 06, 2011 | Computers & Internet
When i plug in my TRANSCEND 4GB USB DRIVE,i got the connecting tone,connecting msg(found new hardware:mass storage device And finnaly problem occured during hardware installation,your new hardware might...
Hi Friend, As you have mentioned that you got the message after installation that it will not work properly, i would like you to check that since you are connecting the USB 2.0 into your system, i would recommend you to please check if the USB ports of the system are compatible with 2.0 version of USB drives
Dec 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Problem for Transcend 4GB JetFlash 110 USB 2.0 Flash Drive My pen drive gets heated up and not recognised by computer. what can i do. pl. help
when i plug in my TRANSCEND 4GB USB DRIVE,i got the connecting tone,connecting msg(found new hardware:mass storage device And finnaly problem occured during hardware installation,your new hardware might not work properly).ssuppose if i unplug it i can hear the removing tone.PLs help me to resolve this.........
Aug 24, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Just bought this of ebay and cant connect to
Hello
The first thing that I would advise you to do is,
Uninstall the WiFi Adapter totally from the System first,
Then go to "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Wifi Adapter).
After this, Press your Wifi button on the system and ensure that it is On, then Scan for wireless networks.
It should connect like that.
(In case you dont know how to uninstall the Adapter, Right-Click on my computer Icon, Properties, Device Manager, then select the Adapter under network adapters, and right click on it, then select uninstall.)
Hope this helps.
Goodluck
Nov 25, 2009 | ASUS Eee PC 1000H Laptop
Exact same problem
firstly I hope the model number is correct. if yes try once again the following steps.
disconnect the Docketport from usb. go to device manager and see there devices marked with yellow exclamation mark. remove them and restart the windows.
1. download the driver and install it
http://www.docucap.com/drivers/DocketPORT465_v1_1_4_setup.exe
2. secondly Docketscan application is needed ..download it too and intall
now try connecting the dockerport
I hope this should make things work.
Aug 07, 2009 | Syscan DocketPORT 465 Scanner
Unable to connect Nokia 3120 Classic with PC
Souns like you need to reinstall the Nokia software. Just pop in the CD and run the setup wizard again. Reboot computer when you are done and try connecting your phone.
If you need further assistance, let me know.
Regards,
Jedi
Mar 20, 2009 | Nokia 3110 Cellular Phone
Cell phone is not connecting to laptop
only thing is driver haven't installed properly and if is than it will be ur cable which is not connecting properly.
Jan 17, 2009 | Microsoft Windows Vista Ultimate Edition
D900i problems with connecting to PC with USB
install the usb drivers on the installation C.D.
Apr 06, 2008 | Samsung SGH-D900 Cellular Phone
Cannot install the device
With regards to this issue, I would suggest you to download windows update since samsung MTP devices are generic driver loaded by microsoft. Then after you have downloaded the windows update press and hold the play button of your device while you are connecting it to your computer, if this is successful a Found new hardware message will pop up on your screen then just follow the on screen instruction on how to install your device. Hope this helps. PEACE!
Aug 27, 2007 | Samsung YP-U2JQB MP3 Player
Canon PowerShot S51S Digital Camera Logo
55 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
