Question about Xerox WorkCentre M20i All-In-One Laser Printer
Display says Scanner locked
MY xerox workcenter M20i display says Scanner locked. can someone help.
There is a green switch located under the scanner area of the machine. You will also see a diagram of locked and unlocked padlocks. Just slide the switch to the unlocked position. Hope this helps.
Posted on May 17, 2010
  • Xerox Master
  • 5,125 Answers
The unit has a transport lock for the scanner. It was originally locked by a label in the scanner module to the left of the LCD panel. It may be below the alphabet keyboard. (When the unit was first unpacked, the label wrapped over the alphabet section, so it was unpeeled and then pulled straight out from the scanner module. Pulling the label switched the lock to the unlocked position.)
I hope this helps.
Posted on Apr 26, 2010
Xerox M20i workcenter will not turn on
Try plugging the printer in to a different outlet and it if it is still not turning on at all you need to replace the power supply. Part# 140N62859 for 110V version or part# 140N62860 in the UK or other places that use 220V. iteminc.com has these in stock and can ship same day. Good luck, hope this helps
Jul 01, 2011 | Xerox WorkCentre M20i All-In-One Laser...
LSU error displayed on Xerox M20i
LSU stands for Laser Scanner Unit. It comes up only if you are trying to access scanner services like scanning a document, using fax or simple scanning.
If it's coming continuously you might need to check connectors within the scanner. Best way is to call a technician from Xerox or take it to their store.
Jun 21, 2011 | Xerox WorkCentre M20i All-In-One Laser...
My workcenter PE220 Xerox is displaying scanner locked and it is not printing or copying. What do I do?
The manual says to unlock it. You will probably need the same password that you used to lock it.
Mar 23, 2011 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Have a Xerox M20i Copier/Scanner/Fax. Display indicates "Scanner Locked" Cannot make copies nor fax out. Please help
If you look under the scan assembly you will see a yellow or green tab which locks the scan head. Try locking and unlocking it a few times then on the final unlock reboot your printer.
Jan 18, 2011 | Xerox WorkCentre M20i All-In-One Laser...
Hi, I have a xerox workcentre which I cannot get to print or copy as the scanner seems to be locked and the only message showing is "scanner locked" does someone have a solution to get my printer...
Look underneath the scanner assembly, you will see a green or orange tab, this is the scan lock. Push it back and forth a few times, it may be stuck. Then reboot your printer.
Hope this helps.
Dec 29, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Scanner locked
Check your green scanner lock which is under the scanner area right in that area where your copies comes out of the machine. This is the most common cause of the "scanner locked" condition. The lock gets accidentally engaged as it is located right where you reach in to get your copies.
If the lock is not the problem then you may have a scanner drive issue.
Good Luck and Thank You for using Fixya.
May 13, 2010 | Xerox WorkCentre M20i All-In-One Laser...
How to unlock my M20i scanner
Release the lock, down the scanner is a tiny plastic piece between the oupt tray (the place where the paper goes out) and the top of the scanner
Fosg2000, Rate me please
Mar 16, 2010 | Xerox WorkCentre M20i All-In-One Laser...
I have a Xerox Workcenter M20i.
You need to replace the fuser. There is a heating coil in the fuser roller that opens. Replace the fuser and it will resolve the problem.
Jan 25, 2009 | Xerox WorkCentre M20i All-In-One Laser...
XEROX workcenter M20i prints codes at bottom of page
someone has gone into diagnostics and enabled Status Print Engine
Fix
1. press menu/exit key
2. enter # 1931 in that order
3. engine test(diagnostic) should be displayed
4. use arrow keys to scroll to, then select engine test(status print)
5. press enter
6. press the "2" key on numeric keypad to disable (status print)
7. machine will revert to Ready to Copy
8. power off and then back on the M20
9. Your done.
May 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
964 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
