Question about HP PSC 2175 All-In-One InkJet Printer
Inserted new printer cartridges but printer still says"remove and check cartridges" help!!
  • 666 Answers
After any maintenance the printer need to be told that the cartridge has been filled in order to do this you need to reset the error count messages
push power button & resume button together then push the resume twice before i release them together..the result is the blink light stop
hope this helps
Robb
Posted on Apr 26, 2010
Insert cartridge
Check printer cartridge compatibility before unpacking a new print cartridge. Make sure that it is compatible with your printer.
Remove the cartridges and check to make sure the electrical strip along the bottom of each cartridge is not damaged or ripped. If the cartridge is new, make sure the plastic protective tape has been completely removed. Place the cartridges back into the machine and turn it back on.
If you need any kind of technical assistance, you can contact support cell at http://vtechsquad.com/printer-support/
Sep 04, 2012 | HP Office Equipment & Supplies
How to insert ink in the prenter
REMOVE THE OLD 2. LEAVE COVER OPEN AND REMOVE THE PROTECTIVE COVER ON THE NEW REPLACEMENT 3. INSERT THE NEW INTO THE SAME CARTRIDGE INSERT AREA 4. RESET YOUR PC TO NEW CARTRIDGE INSERTED 5. YOU WILL BE PROMPTED BY YOUR SYSTEM TO INDICATE IF A NEW CARTRIDGE HAS BEEN INSERTED 6. NOTE THE COST OF THIS TYPE OF PRINTER (MAINTENANCE) IS MUCH HIGHER THAN THAT OF THE LLASER PRINTER
Jan 26, 2011 | Canon Office Equipment & Supplies
Black ink not working, replace cartridge still nothing hp6500 wireless
hold the power button for 15 sec. for a system reset. Try to remove each panel that opens and check for broken pieces of paper Recycle the system by reinstalling the software once again. If you getting error codes then follow this We need to clear out these error codes stored in your printer NVRAM or memory! Shut down the printer and pc associated with it. Remove data cable and reinstall the software for this printer, press and hold the power button on the printer for 15 seconds, then reconnect the printer after software installation is successful. This process will clear the error codes that you keep receiving.
Jan 26, 2011 | HP Officejet 6500 Wireless All-in-One...
How to install colour cartridges of canon ip2772?
1. REMOVE THE OLD 2. LEAVE COVER OPEN AND REMOVE THE PROTECTIVE COVER ON THE NEW REPLACEMENT 3. INSERT THE NEW INTO THE SAME CARTRIDGE INSERT AREA 4. RESET YOUR PC TO NEW CARTRIDGE INSERTED 5. YOU WILL BE PROMPTED BY YOUR SYSTEM TO INDICATE IF A NEW CARTRIDGE HAS BEEN INSERTED 6. NOTE THE COST OF THIS TYPE OF PRINTER (MAINTENANCE) IS MUCH HIGHER THAN THAT OF THE LLASER PRINTER 5.
Jan 23, 2011 | Canon Office Equipment & Supplies
My HP officejet all-in-one printer has been displaying the message: Remove and check right cartridge. I have checked it and cannot get it to print, scan or remove that message.
remove all the ink cartridges, and then unplug the power cord from the back of the printer.
Now, hold down # and number 6 button together, and while holding them down, plug the power back in.
release the hold after about 30 seconds, or the display saying nvram reset .. something like that .. If the printer turns off , then you will have to turn it ON again .. and then insert the ink cartridges ,
this will reset the machine.. and should resolve the issue. Also check if yu have any old cartridge and first insert that and see. if no error on inserting the old cartridge and that if it come by inserting the new on, then it could be the cartridge problem. Will have to try with new ink cartridge.
Sep 07, 2010 | HP Officejet 7210 All-In-One InkJet...
Error msg says 'Alignment problem. Remove tape from cartridge or check trouble shooting. How do I remove tape from cartridge?
A brand-new, never-inserted-into-the-printer, ink-cartridge will have a small piece of tape over part of the mechanism, to prevent the ink from drying-out while it sits on the store's shelf. If you inserted a brand-new cartridge, without removing that tape, just remove the cartridge, remove the tape, and re-insert the cartridge.
Aug 22, 2010 | Dell 924 All-in-One InkJet Printer
I have a hp1200 series all-in-one printer. I
Are these Original HP Cartridges, Hp recommend you dont us refill or generic cartridges in their printers. Check to make sure u removed the print head protective. Also try cleaning the copper side of the cartridge with a pencil head eraser.
Oct 10, 2009 | Office Equipment & Supplies
Printer wont print in color and i just replaced with all new ink cart.
new cartridges can be defective also.
Remove and re-insert the cartridge, double check them,
( leave printer on )
Check printer's Advanced properties are not set for black only,
switch off at mains, reboot,
Run maintainance on it, head cleaner, nozzles etc...
if the same, swap out, the color cartridge it is faulty.
Hope this helps
Regards.
Apr 16, 2009 | Canon i850 InkJet Photo Printer
ASKING INSTALL COLOR CARTRIDGE
Check if the cartridge was inserted correctly (right slot) (remove it and insert it again)
Check if the cartridge is original and the sticker was removed. Turn off your computer, and your printer. Start up your computer and after your printer. Try again.
If the problem continues, insert the old one cartridge (which was removed before) and see what happen...
If stop asking for install color cartridge, you have failure on your new cartridge
and need to be replaced.
Sep 24, 2008 | HP DesignJet 750c plus InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP PSC 2175 All-In-One InkJet Printer Logo
    128 people viewed this question
    Seeker5211
    Seeker5211
