Question about Razor MX350 DIRT ROCKET - BLUE
Where can I buy a throddle control box (under seat) for Rzor 350?
  • kaminsw Apr 26, 2010
    What is the answer for where i can buy a throddle control box for Razor 350?
    Problem Solver:
AT RAZOR THEY HAVE ALL REPLACEMENT PARTS
Posted on Dec 31, 2010
    Problem Solver:
  • 10 Answers
Check ebay
Posted on May 05, 2010
My 92 chevy 1500 350 engine will start bogging and shut off and the motor is flooded. Does anyone know why?
Make sure your breather or breather spacer has not pinched the wires going to the tbi throddle boby injection ,,,or rubbed a wire causeing it to ground out,,, also just to to the left and foward of the tbi there is a large square box 1.5x1.5 with wires pluged in make sure the wires are not melted or naked and touching each other,, check all your wires on the intake in that area make sure there nit melted togther or cracked and touching
Mar 09, 2015 | Chevrolet 1500 Cars & Trucks
Fix a power seat in a 2005 jeep grand cherokee when only one side works on the horizontal.
About your seat, On the Jep seat under the seat you first have to remove the seat for easy access, on the botton of the seat you will se the motor which connects to a plastic box with 4 or 6 outlets this is called the seat control transmission. Each one of the connections have a cable like a speedo cable that connects to the transmission with a screw type cable connection unscrew them one at a time most likely one or more of the inner cables are broken. you can replace each one of the cables can be replacedor you can buy the entire transmission box
Feb 18, 2015 | 2005 Jeep Grand Cherokee
How do I open the seat on yamaha grizzly 350 Quad?
what year? pull cable under seat on some? (under plastic ) has looped cable , just pull it. along edge of seat on others small lever pull up towards seat.
Jul 13, 2014 | ATVs
How to hook up a kick down cable on a turbo 350 with a 5.7 350chevy properly
The turbo 350 ,,,,uses vacuum and a cable,,,to kick down,,, just run a vac line from intake to the regulator on back of the trans,,,pull the cable out as far as it will go,, hold your throddle wide open,,, will get you close,,, you may have to make a bracket to the kickdown in the proper place,,,
Jun 25, 2014 | 1995 Chevrolet K1500
87 chevy 350 tbi will only start if if pour gas in the throddle body then keep it running by pumping the peddle. It seems to starve at higher rpms, and when it does idle the rpm's swing from hig
Sounds like the fuel pump is going bad(or in this case,has gone bad). I suggest that you change the fuel pump and use a fuel cleaner in your gas tank as dirty gas may have caused the problem to begin with.
Nov 27, 2012 | Chevrolet Cars & Trucks
How do slow down the idle on a 1995 chevrolet 350 engine
there not suppose to be any adjutments made for idle. high idle is usualy caused by a problem the computer is trying to confresate for something by keeping idle high ,check see if check eng light is on .check for bad coolant sensor corroted batt cables,poor battery connections, 02 sensors functions.if you really want to take down idle there is a small screw on throddle body in some model look for a air screw ,a large straight edge screw near air intke or on throddle body .but i dont recomend adjusting idle unless you ve fixed the problem that causing the pcm to raise the idle to prevent stalling of the eng
Aug 28, 2010 | 1992 Buick Regal
05 EXPEDITION ELECTRONIC PROBLEM
needs reprogramming covered under a tsb at the dealer
Feb 09, 2009 | 2000 Ford Expedition
FANS DON`T TURN OFF
Relays are located in either the Power distribution box (by the battery) or the junction box under the dash. If that is not your solution I would try the Body Control Box which is under the fuse box under the dash. I just went through a similar problem, check out 1999 dodge caravan with headlights out and park lights on all the time. I replaced this body control box($350 at the dealer) and it took care of my problem. everything works now. Buy it from a wrecking yard it's a lot cheaper. however you will probably have to pull it out yourself.
Jul 06, 2008 | 1999 Dodge Grand Caravan
Razor MX350 DIRT ROCKET - BLUE Logo
262 people viewed this question
Top Razor Cycling Experts
Ted Maxwell
ray gallant
 steve
steve
Are you a Razor Cycling Expert? Answer questions, earn points and help others
