Question about Samsung WF337AA Front Load Washer
Samsung vrt check pump filter - Samsung WF337AA Front Load Washer
5 Suggested Answers
SOURCE: filter
I have a vrt ... I hope this helps.... Take of that little door on the front. Have a bucket or bowl ready. Bring down that little black hose, turn the white cap around and pull till it comes off. Drain into the bowl, turn the white filter cap counter clockwise to release some of the suction and wait till the hose stops draining. Remove cap, clean under running water w/ toothbrush. Manual says to make sure that the interior is free of anything (I wiped mine out) and then put it all back together again. Good luck
Posted on Sep 03, 2009
  • 330 Answers
SOURCE: our samsung vrt washer starts
the pump is being blocked by something on the other side of the filter or one of the hoses under there is blocked but some water is still getting out but not quick enough there is a sensor to detect this & then tells the computer who displays the error code if your handy enough and strong enough you can turn the machine off lean it back and get under there with a torch and pull it all apart you will need a pair of multi grips & a philips head screw driver only three screws & 2 hoses to take off.once you put it back together if it doesnt work it needs to be replaced. they sometimes take the electronic board out as well.good luck
Posted on Jan 15, 2011
Lanijo58
  • 73 Answers
SOURCE: How do you remove the
Actually there should be a little door you can access at the bottom front to clean out your pump filter, I'm including my washers pictures. 1) You first open the little door at the bottom. You do not need any tools, just something to drain the water in to. 2) Unscrew the hose closure, put your hose down into the drain bucket. Drain all the water out, you may have to empty the bucket so you can get the hose lower next time. 3) Next unscrew the filter itself. Get anything out inside the hole, in my case it was a toothpick, I take a paper towel and dry out any grit or hair. 4) Put your hose closure back on, it is held in a clip, Then screw the filter back in. That's it. I would also recommend cleaning out the drawers that hold soap, bleach and fabric softener. Also clean around the rubber ring, it will help your washer last longer. lanijo58_3.jpglanijo58_2.jpglanijo58_1.jpglanijo58_0.jpg Hope this helps you
Posted on Jun 02, 2011
ginko
  • 19396 Answers
SOURCE: samsung vrt steam Brand new first load
Hi.
You need to check the drain filter located in front of the machine at the bottom, behind a trim panel or a service door. If the problem occurs again the machine is faulty and must be repaired. Parts such as drain system, drain pump, pressure switch and control panel may be responsible for drain problems.
Check the position of the drain hose. Ensure that the height is as specified by the manual or you get siphoning and drain does not end.
Access the drain filter. With most front loaders this located in front at the bottom in a corner, there should be a trim or an access panel.Top loaders have an access panel at the back, or more commonly the pump is accessed from underneath, bending the appliance on one side and securing it.
The machine has a pressure switch. It is a sensor connected to a long thin rubber hose. The pressure switch is often in control assembly. Clean the hose and the switch. One way to test the pressure switch is by blowing into the switch, but manufacturers say this must not be done as you can damage a good switch.The pressure switch is difficult to test in full. Testing is done either reading voltages while machine is working or reading Ohms at the switch with tub empty and full. For safety reasons I suggest users to avoid performing tests or maintenance that must be done with power on.
Here a page about drain/spin problem.
Start checking drain hose and drain filter. If machine is a front loader the drain filter access is located behind the door at the front bottom side of the machine.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Posted on Sep 09, 2011
Samsung vrt front load washer WF218ANB/XA Burned up the drain pump. Installed a new one, now washer will work until the spin cycle. In spin cycle the door lock clicks and it will not drain or spin
Make sure the drain filter is not clogged. Most Samsung have an access door in the lower right hand corner to access and clean out this filter. If this is clogged or the drain hose is clogged, you will have these spin and drain problems.
Nov 10, 2016 | Samsung Washing Machines
Where is the drain filter located on the Samsung Silver VRT front load washer?
I have a similar model and there is a bottom panel which can be prized off with a flathead screwdriver or similar. Behind this panel you will find the filter.
It sounds as though you know what you are doing with these machines but hopefully you just missed this trick.
Andy
Nov 13, 2013 | Samsung WF337AA Front Load Washer
Samsung VRT error code dc
dc means clog in the filter. look to the lower left front of the washer for the filter door. Take off the door and pull out the short hose. Empty the water from the hose, this could be lots of water be prepared. Then pull out the filter on the right by twisting counter clockwise and rinse the filter. Put it back together and the error should go away
Oct 20, 2012 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung WF337AA Front Load Washer Logo
611 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
