Question about Microsoft Xbox 360 Console
Once you use the XYLX to bypass parental controls, can you enable the old password again? Or do you have to create a new one?
4 Suggested Answers
Wilhelm_I
  • 23 Answers
SOURCE: xbox 360 parental control bypass
Hello.
There is a little insider trick to disable it:
Go to Settings, Highlight Parental Control, When the screen pops up that says Enter Pass Code press: X, Y, Left Trigger, X. You'll be taken to the parental controls screen where you can disable the passcode previously entered.
I hope this helps :)
Kind Regards,
Wilhelm@Xboxexperts.com
Posted on Mar 06, 2009
SOURCE: How can i get rid of my Parental Block for my xbox
lol get you mum to reset their password on the computer then they can type their password in as their new 1
Posted on Mar 20, 2010
  • 111 Answers
SOURCE: Forgot Xbox 360 parental controlls password
they can either use the password reset answer or contact xbox live via the phone.http://support.xbox.com/support/en/us/nxe/contactus.aspx
good luck
Posted on May 24, 2010
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
Tip
Bypass Mitsubishi HDTV VChip Password
Bypass or Reset Mitsubishi HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Bypass Mitsubishi HDTV Front Panel Lock
Mitsubishi WS-55511 Manual Download
on Apr 30, 2010 | Televison & Video
Tip
Reset Mitsubishi HDTV VChip Password
I hope that helps.
Unable to get parental controls to work in Windows Vista Ultimate
Hi, Well windows has 1st launched this service with vista..on per user basis. It was not mentioned by you do u want a solution while logged in as administrator or user. I have given answers for both of them. As per your requirement you can select. For Administrator In d 1st case make sure that you r logged in as the administrator, while following these steps:
  1. Click on start button
  2. Go to control pannel, n select parental control.
  3. A User Account Control prompt will appear asking if you would like to continue. Click on the Continue button to proceed with opening the Parental Control
The screen which opens is the control panel.From here you can apply parental controls for the whole system or even for the standard users. For creating a new acc
  • Click on the create a new user tab
  • In this screen you would type the login name for the new user account that you would like to create. We also suggest that you leave the option labeled User must set password at next logon checked so that when the user logs on for the first time they will be prompted for a new password enabling them to keep their password private.
  • When you are ready to create the user, you would click on the Create Account button to finish the creation process. You would then be brought to the Parental Controls page for that particular user. J
Just press the OK button to get back to the welcome screen. Now from here you can keep the parental control setting as per your requirement on the following Global game rating systems setting, Family Safety Options, Activity Report Reminder, Web Restrictions Page etc
Now if you are a user/ domain and want to put up parental settings follow these steps;
  • Open the Run dialog box.
  • Type gpedit.msc and click OK
  • When the UAC prompt appears, select Continue.
  • The Group Policy Object Editor window will appear.
  • Under Local Computer Policy, expand Computer Configuration.
  • Expand Administrative Templates.
  • Expand Windows Components.
  • Select Parental Controls.
  • In the right pane, right-click Make Parental Controls control panel visible on a Domain.
  • Select Properties.
  • Select the Enabled radio button and click OK
  • Close the Group Policy Object Editor.
  • Resart the machine, for changes to take effect.
Nov 25, 2009 | Microsoft Windows Vista Ultimate Edition
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Tip
I hope that helps.
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tip
How to bypass Windows XP password? We often meet the headache stuff that don't...
How to bypass Windows XP password? We often meet the headache stuff that don't know the Windows system password at the critical comment. How to do if you made a Windows XP password that you never be care of it? How should you do when your computer has parents controlled by the XP Administrator password? Or you need to borrow a friend's computer to carry out emergency work, but you don't know the admin password...Let's share some tips about how to bypass windows XP password.
First things first, try the guest account. Simply enter 'Guest' in the user name box, or click on the account labeled Guest. Sometimes people will have these account enabled without even realizing it, and many times they are left without a password. If this doesn't work for you, or you require a little bit more access than the Guest account provides, read on.
Next up is Windows XP's built in 'Administrator' account. This account is created during Windows installation, and is not accessible under normal circumstances. Many computers, especially those that come from Dell or similar companies, leave the Administrator account without password protection.
To get to this account, boot the computer into safe mode. You can do this by holding down the F8 key during startup, and selecting Safe Mode from the Windows boot menu. Once the computer boots into Safe Mode, you'll have access to the Administrator account. Things will look a little weird in Safe Mode, but don't worry, things will be fine when you boot normally again.
Once Windows finishes booting, try getting into the Administrator account, leaving the password field blank. If you're unable to get in this way, then there is a password on the account, and unless you can guess it, you're going to have to try something else, and you can skip the next paragraph. If you're in, then there's no limit to what you can do.
Besides, you can also take use of Windows password reset CD to remove Windows XP password if you forgot Windows XP password. Well, how can you get Windows password reset CD? Just download Windows Password Unlocker and a blank CD, you can DIY a Windows password reset CD in 4 steps.
In fact, Windows Password Unlocker can be used to bypass windows 7 password, bypass windows vista password , bypass windows NT password and so on.
on Mar 16, 2010 | Computers & Internet
Parental control/lock on Mitsubishi WS-55613
I can help you unlock your Mitsubishi HDTV V-Chip parental lock.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Aug 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Parental control
hi crakmonk
At the screen where it ask you to imput the password enter 7444. the old password will be deleted and you will have to setup an new one.
Just leave it blank to not have a password setup.
or look here for more info Open Tech Support - Playstation 2 Parental Control Reset/Bypass
riz.
Jun 22, 2008 | Sony PlayStation 2 (PS2) Console
V chip password
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
Mar 20, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Microsoft Xbox 360 Console Logo
130 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
