Question about Maytag MSD2756G Side by Side Refrigerator
Not cold Had relay recall fixed in Oct. In January fridge and freezer went warm. Tech came back and fixed it again. Now the same thing is happening. The lights are on but both sides are warm.
    President:
  • 2,468 Answers
Are they putting in the right ptc overload relay? there are 2 styles for this model,remove the old one off the compressor body in the lower area of the unit and take it and the full model number to an appliance parts supply warehouse and they can check and make sure you had the correct one before,and can get you the right replacement if the old one is bad or incorrect
Posted on Apr 26, 2010
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
GE Profile- Freezer/ Fridge at 56 wont go cooler!
HI,
All i can say is you will require a tech to get this fixed.
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing,
check vents in refrig. make sure no blockage, controls should be in the middle setting,
check make sure compressor is running.For this you will require a tech..
Goodluck.
May 03, 2008 | GE Profile PSW26P Stainless Steel Side by...
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
Clicking noise and fridge/freezer not cold
Hello, This problem is going to be as you suspected the relay. This part is fairly cheap around $30 if you are going to do the fix yourself. The relay is mounted to the side of the compressor. I would change both the overload and relay because of the burning smell you had. If you have an appliance tech in to look at it I would say it's going to cost some where in the region of $150-$200. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Mike
Sep 09, 2009 | Refrigerators
Older Kenmore side by side, freezer warm....again!
"Fuzzy Ice on the back wall" yep, this sounds like a defrost system problem. You say you cleaned this fuzzy ice but, the real ice is behind that wall. I would get it fixed but call several service people and get a price. My guess is that once the defrost system is working then the Ice maker will work. If the freezer is not getting cold enough then the Ice maker won't work.
Now, the drain can cause a problem too but this is an easy fix. Pull out the bottom drawer in the freezer, look in the back under the cooling coils and you should see the drain hole. Keep this area clear of Ice and any thing else. Some tubing with a little air pressure will usually clear any blockage. A little hot water down that drain won't hurt. The water should drain to the a plastic pan under the Ref. Take the front grate off at the bottom of the Ref, look in the pan to make sure it went through.
This should be checked often, once a month or so.
Dec 02, 2008 | Refrigerators
Fridge too warm
I had a similar problem several months ago.
1) Top freezer compartment is getting TOO cold. The ice gets so thick, it blocks the channels of cool air from the freezer down to the fridge compartment (hence fridge too warm)
SOLUTION: Turn fridge/freezer off to fully defrost, then turn back on.
NB: This might only be a temporary fix, and you will find in a few months time the same thing happens?
2) In my case, I required a replacement of the "controller" board which fixed the defrosting problem of my freezer compartment.
Good luck.
Oct 26, 2008 | Refrigerators
Fisher & Paykel Model #E522BRX Fridge portion not working but Freezer OK
Hope I'm not too late - I had EXACTLY the same problem and the freezer fan wire was broken. I fixed it an documented everything in http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf. Good luck.
Aug 14, 2008 | Fisher and Paykel Active Smart E522B...
Fridge wont get cold and freezer gets cold then gets warm
Sounds like to me you have a defrost issue. If your fridge is only 2 months old don't sweat it and call out a Whirlpool warrenty certified tech. to fix the problem. And sorry to say age does not matter with fridges any more. The good ole days of fridges lasting 20 years is over now it's 12 years if your lucky.
Feb 24, 2008 | Jenn-Air JCB2280HES Side by Side...
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
After defrosting the freezer the whole fridge doesn't work (is warm!)
sounds like the compressor is locked up or the relay on the compressor is bad. whats happening is its drawing too much current and cutting out from the overlaod relay. that may be a bad compressor or the start relay. both the overload and the relay are under the black box on the front of the compressor. you will need to check the relay to make sure its good, and also the compressor. there should be a wiring diagram on the back that will tell you how many ohms from terminal to terminal on the compressor. hope it helped if its a newer unit the relays are electronic and if you shake it and hear like little sand pebbles in it most likley its bad and thats why it wont run.
Aug 10, 2007 | Danby DCR34 Compact Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
70 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
