I have a Mitsubishi WS 65511 that I brought in Nov. of 03 . My blue convergence does not move left o or right to line up with the center cross hair. As a reult, the blue on the screen creates a shadow. So, I removed the front pannel and manually made some adjustments. I want to have the same adjustment vaules that I had when I first brought the TV. I have the sevice manual. Should I manually put in the information from the service manual before I get the new part or should I do it after the new part is put in? I am not sure what part to order. Do I need HIC-STK 393-110 and if so, do I need one or two. Or do I need a new convergence board? Thanks Angela
Where do I get original Mitsubishi parts for my TV model WS 65511? thanks
Go on line and get an original Sanyo STK 393-110. Next, restore the blue centering rings back to where they were before you moved them. Look at the paint marks on the rings for reference if you are not sure. Replace the IC and check the resistors nearby for signs of overheating and proper value. Also check the fuses that supply the 24v to the IC. The service manual will show you the fuse location and give you the resistor values in the blue horizontal and vertical circuit. Checklist: You need a de-soldering tool or a good quality Dry Wick. Have a small tube of heat sink compound to liberally apply to the new chip. The hardest part will be lining up the double rowed pins on the chip and getting them to seat at the same time. Next, go to the convergence menu and follow the instructions. Good luck! PS you might want to remove the chassis from the cabinet to make it easier. Be careful to unplug the speaker plug and untwist the wire ties from the cabinet. Be very careful, this job is not designed for beginners.
Convergence problem.
The convergence IC's need change, or you need a new convergence board.
You can get The IC's at
www.mcmelectronics.com or a new convergence board at www.partstore.com1,007 views
I have a Mitsubishi WS 65511 that I brought in Nov. of 03 . My blue convergence does not move left o or right to line up with the center cross hair. Do you have fix or a part #
