Question about Whirlpool LER5636L Electric Dryer
Does not turn on when I push the on button. have checked fuse and plug.
  • Whirlpool Master
  • 43,501 Answers
A dryerDoes not turn on when I push the on button. have - 2_bing.gif may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 28, 2010
We're is the fuse located for the electric water heater I have hot water on gas but the electric heater just stopped when I'm plugged in
It is not fused, they don't use fuses and haven't for decades, it is hooked into the house current at the breaker box for the house.
Jul 21, 2016 | Water Water Heaters
Unable to turn on tv at the base of the tv or the remote
check make sure you have power
check the power strip is working
check electrical and power cords
unplug the tv from the wall and remove the plug from the tv
inspect the wire or plug connectors and plug areas
check the batteries for the remote, if not sure replace them all
go to fuse panel reset breaker, trip and reset breaker
than reconnect everything and try turning tv on
see if you can find reset button, push to reset
find out if the tv has a fuse, check the fuse
after all that a new tv/ see if it worth repairing most of the time it cheaper to buy new one or a referbushed unit.
Sep 17, 2015 | Philips Televison & Video
My dyson dc14 when you push the start button doesnt turn on? could the button need replaced
The most likely fault is a break in the cable near the point where it enters the machine, if cable is ok it could be the switch, or it could be a fuse in the plug if you have fused plugs. Get someone to check the cable, often the broken part can be removed, and you end up with a slightly shorter cable by about 20cm
Jul 15, 2014 | Dyson DC14 All Floors Upright Vacuum...
Starting problem on kangoo
Check the big fuses in the power distribution box under the bonnet ,this is a UK reg vehicle kept outside no doubt and these fuse connections under the bonnet do get damp ,if still no joy for whatever reason then but a manual push button starter switch and wire them in direct manual overide ,power to switch then direct to the glow plugs ,so when the light dont come push button in for 10secs and no more and away you go,Clean the big fuses and spray with some 3in1 or a oil can with engine oil not that wd40 and lubricate the connections where the fuses push into.
Jan 19, 2014 | Cars & Trucks
AC isn't working
when a fuse keeps blowing it can only be one of two causes. either the consumer is loading the circuit too much due to a bearing problem or rusty component, or there could be a short circuit to ground. disconnect the blower motor plug connector and turn your a/c on like normal. if it blows the fuse again, replace the blower fan motor. if not, start checking the wiring for any exposed copper that might touch the ground-negative.also inspect all the plug connectors for water damage and corrosion.
Jul 08, 2013 | 1997 Toyota Avalon
My Miele Novotronic W502 does not have any power although it is plugged in
I would check that I do have power present at the outlet. If power is present the next step would be to check the fuse on the push button switch. Unplug the machine and then gain access to the push button switch by pulling the knob off after that you will need to take the orange plastic key from behind the detergent dispenser, and use it to remove the facia panel by pressing down slightly and wedging the key in between to gain access to the electronic. The electronic can be removed by taking out the 2 Torx 20 screws one on each side after that remove the connector plugs from the push button and unseat it from the clip. If you the fuse has continuity it could be a problem with the interference capacitor or the electronic.
Feb 01, 2012 | Miele Washing Machines
Garmin nuvi 255 won't turn on
Have you tried doing a hard reset,try using the reset button on the bottom of the gps under the serial label.Or try holding the turn off button for about 10 seconds,good luck.
Aug 31, 2009 | Garmin nuvi 255W GPS Receiver
Pioneer Pro-118 won't turn on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine. Check all three fuses while you're in there.
Feb 12, 2008 | Pioneer PRO-200 60" Rear Projection...
TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Whirlpool LER5636L Electric Dryer Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
