Question about Roper RAS8445KQ Top Load Washer
Spin cycle slow hard to get going have to start by hand
Model ras8445kqo washer is 7 years old this is the first problem weave had
  • Roper Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
Posted on Apr 28, 2010
Have old kenmore elite he3 washer. Have wet laundry after spin out. Have checked ball be low drum, replaced strainer, pump motor, cleaned all hoses. Did a test run in the drain and spin cycle. For like 7...
If the washer is taking more water during spin, then most likely it is thinking the water level is low for the load. It is a smart washer and tries to adjust water according to load. This can mean the level sensor is giving wrong sensor. I would try to run the washer with a cleaning agent (not bleach) available from specialist stores or washing machine retailers.
Also observe if the drain pump is running all through the spin cycle. If not that is likely causing water to remain. But controller is thinking there is no water and not starting the pump when required.
You should be able to locate the parts in these diagrams.
KENMORE ELITE Washer Parts Model 11049962600
Sep 20, 2014 | Washing Machines
I have a Whirlpool Ultimate Care 2 Imperial Series washer that doesnt spin out very well. It will sometimes spin out but leaves the clothes very damp. Sometimes the washer will try to spin itself out but ...
First thought is that the cycles are off.we have the same problem with ours right now. That slow spin speed concerns me. The motor could be going bad. If this washer is 10-12 years old, you may want to look at replacing it. Does the machine ever start agitating before it finishes filling. If so, the cycle mechanism is going bad. This has a whole host of potential problems. Ave a rep look at it. He can narrow it down quickly.
Feb 06, 2013 | Whirlpool Washing Machines
I have a 7 year old Frigidaire washer (Model #GLWS1349AS1) and the water drains really slow and the spin starts before all the water is drained and then the washer leaks as water is still in it during spin...
you have a restriction in the drain somewhere or there is something inside the pump housing,chk every line from the tub to pump to drain pipe and hoses for blocks or kinks
Apr 09, 2010 | Frigidaire FTF2140ES King Size Front-Load...
I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Feb 04, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Clacking sound on agitate cycle only, no noise on spin
The agitate cycle uses the motor and a spring to function. The spring is made in pieces and asit gets older some of the sections of the spring break. To verify that it is not a loose drum. Ope the washer during the wash cycle andhold the drun by hand. If the noise stops lool for the loose bolts or replace the springs, they may be weak after that many years.
Aug 18, 2009 | Washing Machines
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
Roper RAS8445KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
