Question about Amana NDE2335AY Electric Dryer
Drum will not turn
The dryer will heat and sounds like it wants to run but the drum will not turn,, the belt is only 1 year old and connected to the motor.. need help please?
  • Cbecker0056 Apr 27, 2010
    the dryer is less than 4 yrs old
  • ElectricMan
    ElectricMan May 11, 2010
    how old is the dryer?
  • 4 Answers
Hi if you take the back off make sure its unpluged 1st look at the very bottom there is a small metal like fuse maybe the size of a box of matches unplug the two leads that connect to it and pull from the two left attached take it to commet they have them they cost around 10.00 and just replace it youself its simple putting it back on the way you took it off
Posted on Apr 26, 2010
Testimonial: "thank u very much very helpful "
We're original owners of this 10 year old dryer. For the past year it was very noisy (squeaks loudly when in operation). I never isolated the cause, just figured the bearings were failing. Last night it...
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Jan 09, 2011 | GE Profile DPSF505GW Dryer
23 year old dryer, model # 86673700, drum won't turn. will heat up and motor wil run. how do i get in to check the belt?
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections. Remove the lint filter screws and filter.
Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Please rate me
Thank you
Aug 14, 2010 | Kenmore Dryers
The dryer won't turn, it is only 18months old.
Check your belt from the drum to the dryer, it sounds like the belt has come off of the idler pulley or the motor.
If you have to check your drum belt and if you have a front loading machine.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 15, 2009 | Frigidaire Dryers
It is not spinning
are you sure the belt didn't break, sounds like the motor is turning though, you'll find out when heating element gets too hot from drum NOT turning and drops out until cool
Sep 24, 2009 | Dryers
The drum won't turn - sounds like motor is trying to work - only 2.5 years old
IF THE MOTOR SOUNDS LIKE IT'S RUNNING THE BELT IS BROKEN PULL THE TOP OF DRYER OPEN AND SEE IF THE BELT IS AROUND THE DRUM
Aug 19, 2009 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Kenmore dryer not running
Ticking sound is the timer running--so it is not the problem unless a contact has failed or a wire has come loose.  Broken door switch, thermostat failed in open position, or clogged lint filter/exhaust vent/outlet would keep unit from running.  If you can hear the motor running but the drum is not turning then the drum belt is broken.
Jun 04, 2009 | Dryers
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Amana NDE2335AY Electric Dryer Logo
254 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
