Question about Dell OptiPlex SX270 PC Desktop
How do you install a hard drive to a dell optiplex sx270
  • rc May 11, 2010
    External hard drive, or internal hard drive?
  • Dell Master
  • 5,469 Answers
This computer only has one space for a 2.5" hard drive (IDE ATA100). Unplug all external cords from the computer (including the power cord) and press the power button (this grounds the system board). Remove the mounting plate and cable cover if these are attached. Place the unit on its side with the back connectors towards you (power supply to the left) and slide the release button towards the right. The hard drive door should open. Ground yourself by touching unpainted metal on the case. Rotate the door up and remove the data cable from the drive (carefully). Raise the release tab (on the opposite side from the data cable) and pull the drive up and away from the door. If you need to, remove the sled from the old hard drive (4 screws, 2 on each side) and attach the sled to the new drive. (If the new drive came with a sled, skip this step.) Slide the new drive onto the drive door. Attach the data cable carefully to avoid bending the pins (just the ribbon section is used, the other 4 pins are left bare). Slide the drive into the drive bay and lower the door to lock it into place. Replace the cord cover and mounting plate if in use and connect all of the external cables. Plug the network cable into the wall jack, router, or modem before connecting it to the computer. Follow the directions that came with the drive for any software installation. Reboot the computer, partition and logically format the hard drive. See the OS documentation for this step. Test the hard drive by running the Dell Diagnostics, http://support.dell.com/support/edocs/systems/opsx270/en/ug/adtshoot.htm#1172888 . Install the OS for your system.
If the chassis alert comes on at the next reboot, reset it (contact IT if there is a password on the BIOS).
I hope this helps.
Posted on Apr 26, 2010
ginko
  • 19396 Answers
SOURCE: Can't get the cover off our Dell Optiplex SX270...
See here: Removing the Computer Cover.
Once inside the computer see:Inside Your Computer
Click here to get complete documentation.
Posted on Apr 11, 2009
  • 3 Answers
SOURCE: locked my optiplex SX270 how do I unlock it and change password?
you must open the top cover by relase the green lach in the back off computere to rhigt side
and phuse the cover out from the front side.
on your bord you have jumpper near the chipset take him out power on after off back the jummper home and try.
more option .take out the green plastik with in the left corner you can see the coin battry remove wait 1 min and insert back. go to f2 bios mode and change the time zone
good luck
Posted on Jul 14, 2009
proton77
  • 1183 Answers
SOURCE: how to install 1.5TB hard drive in a dell optiplex
Kindly follow the link below to add new harddrive to the system
http://support.dell.com/support/edocs/systems/opsx270/en/ug/hd.htm#1136008
Thanks for using fixya
proton
Posted on Aug 15, 2009
Testimonial: "Thank you for the help. Very professional"
pappapumpdaf
  • 635 Answers
SOURCE: error while trying to install windows xp
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
In your case though, this is most likely one of 4 capacitors that are known to blow out on any SX270. Slide the bar at the back of your PC to the remove cover side and look inside for swollen caps. Remove the fans and cpu cover as well and check around there. Replace any bad ones you can find with old caps borrowed from an old motherboard if you have one, or new ones from any decent electronics parts warehouse. This fix has worked for me on every SX270 I have ever had.
Posted on Mar 10, 2010
  • 138 Answers
SOURCE: Optiplex SX270 LED light code
Hello
The LED code you described indicates a memory failure. Remove and re-install all of your memory. If this does not fix the issue, remove all memory and insert one stick at a time until the unit turns on. Replace faulty memory.
Here is the LED Code guide from Dell...
http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1235408
Posted on May 01, 2010
I tried to install windows in my DELL optiples sx270 but i keep getting an error E61 Media Test Failure and unable to install windows
It indicates a bad hard drive, if you have repeatedly tried to install windows and it is coming up E61 Media Test Failure probably means there are bad sectors on the hardware.
Jan 11, 2011 | Dell OptiPlex GX270 PC Desktop
Hello
May 01, 2010 | Dell OptiPlex SX270 PC Desktop
Error while trying to install windows xp Stop: 0x0000007B on a dell Optiplex sx270
Mar 10, 2010 | Dell OptiPlex SX270 PC Desktop
I have a dell optiplex sx270 version PC.I had shut it down ,as we had a holiday the next day.I later tried to switch it on after my holiday .But it won't switch on .However the power adapter indicator...
it seems like the power button is at fault i doubt it will effect your data unless you pass it to a bad repair man who may erase everything your hard drive is a seperate entity and can be removed for backup
Aug 06, 2009 | Dell OptiPlex SX270 PC Desktop
Opening case
Hi
Check here for an illustration / guide to open OptiPlex SX270 cover.
If you still have problems get back to me
Mike
Jul 25, 2008 | Dell OptiPlex SX270 PC Desktop
Dell hard drive
If you can figure out how to remove the hdd, you can just use the restore discs to reinstall the OS using the windows key on the machine (usually a sticker on the side). You wouldn't need to rebuy a key.
Good luck getting that hdd out!  :)
May 09, 2008 | Dell OptiPlex SX270 PC Desktop
Dell OptiPlex SX270 PC Desktop Logo
512 people viewed this question
Alun Cox
