Question about Crunch Powerzone P2200 Car Audio Amplifier
No sound? I have a crunch powerzone 1500 watt amp. It was working fine now all of a sudden there is no sound. all my connections are good I have tested my speakers on another amp, they are fine. I've checked my rca cables. The power is on, and the green light is on, it is not in protect mode. does any have any ideas as to what could be wrong?
  • Nbolda Mar 24, 2008
    ya i checked them they are good, thats what i dont get
Good day,
I have a Crunch P2200 Powerzone.Lately,my fuse from my dc12v source bursted but the fuse on my P2200 was intact and okey.I later found out that R550 was burned (i dont know the value coz it was burned but measures 150 ohms. pls tell me the exact value)and C550 was cut open (i tested it & found okey so,I just resolder it back)
The problem now is that it has an audio but very weak (less power)
What is the function of the ic KA7500B does it has something to do with the problem or just the r550 changed resistance and did not have the right value anymore?
Thank you very much and more power!
Posted on Oct 19, 2009
I am having similar problems on my amplifier, because what happened on mine was i blew my sub for being a idiot by playing it too high and i decided to get a new sub, the new sub wasn't playing when i hooked it up with my amp, and i thought it was the leads so i messed around with them for two hours and it made no difference so i got my mates amplifier and hooked it up and now it works, the problem that i realized was that there is no live connection from the speaker output (although the amplifier itself works) this was the result of my sub blowing it must have messed up the chip or summat, so i advice check it out from someone if they can fix it because i am still trying to get someone to look at mine, or better yet return it to the person you brought it from :)
Posted on Apr 24, 2008
  • 807 Answers
Check the outputs on the stereo. Maybe there's no audio signal going to the amp.
Posted on Mar 24, 2008
  • 323 Answers
When all else fails, hook up the amp in your friends vehicle and see if it works. Also try hooking your subs up in stereo. Switch + and neg cables around and see if you get anything that way. Could be your speaker cables also. Run a direct connect: like take out the sub and run + and neg directly to the amp. If it works you know you have a wiring problem in the box.
Posted on Apr 19, 2008
Crunch 2000.4 car amp, need help tuneing
re-check the speaker connections are correct and use a matching ohm test speaker on the other connections for a sound check. Sounds like hi frequency output into the sub amp. Sub-woofers are a mono signal!!
Jul 17, 2017 | Crunch Car Audio & Video
I can't figure out if my crunch powerzone pzi 250.2. 1000 watt amp is compatible with my 2000 watt pioneer premier 12" sub, I seem to be blowing fuses will someone please help me out
There may be an impedance mismatch between the two. If the amplifier "sees" a load impedance of 2 ohms or less, for example, the fuse(s) will open to protect the output stage from failure.
Feb 09, 2017 | Pioneer Car Audio & Video
I have a Crunch Powerzone Pzi2250 1000 Watt Amplifier. and the red light blinks. What does that mean
My crunch powerzone pzi2250 1000 watt 2ch amp is stuck in protect mode. How do I fix this at home
Jan 16, 2011 | Crunch Powerzone P4175 Car Audio Amplifier
I have a qiestion on a 1300 watt 5 channel crunch amp.
whats the question? if its a power zone its a very good amp
Feb 02, 2010 | Crunch Powerzone P2200 Car Audio Amplifier
Good day, I have a Crunch P2200 Powerzone.Lately,my fuse from my dc12v source bursted but the fuse on my P2200 was intact and okey.I later found out that R550 was burned (i dont know the value coz it was...
Hi mate i had similar problem my 12 volt blow all good i thought every thing worked after fixing but i noticed my bass was weak subs would still move a lot but not pump no real bass coming from them .After eliminating most things i hooked dvd player to amp with cd inside to test if head unit was outputing bass and i found that my head units bass out put had a cry but fuse in headunit was fine and i was fused in 2 spots from 12volt source new head unit and all good again hope this helps
Oct 19, 2009 | Crunch Powerzone P2200 Car Audio Amplifier
Power cutting on and off
had a similar problem with an 800 watt legacy. remounted it in a cooler place away from the speakerbox, no more problems it would overheat and shut itself down until it cooled
Jun 09, 2009 | Crunch PZi1000.1 Car Audio Amplifier
Amp will not power on at all all of a sudden, fuses look fine
Hello schapman81,
You do not say if there are any indications or errors displayed.
I'd recommend you follow the troubleshooting steps here starting at Step 2 (B+ and Remote Voltage:). This should tell you if there's a problem in the wiring or if the amp itself has failed.
Hope this helps.
May 09, 2009 | Crunch Powerzone P2200 Car Audio Amplifier
Should I use this Jensen LXA300 AMP to power my DS930 kicker 6x9's
i have a 2 channel boss amp running my 6x9's & a candence 2 channel on my bass ..they say for ur mids & high's a 4channel is best , but i like the 2 channel better ... so i think u wil be fine with the amp uhave , just be sure 2 tun it down so it wnt blow ur 6x9's...
Oct 02, 2008 | Jensen LXA300 Car Audio Amplifier
My subwoofers cut out
You are most likey running too much power from the amp to the speakers.. you might want to try just notching the bass down a notch or 2.. just enough that the bass will hit
Nov 16, 2007 | Car Audio & Video
Kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Sep 25, 2007 | Car Audio & Video
Crunch Powerzone P2200 Car Audio Amplifier Logo
254 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Tygh Duval
Tygh Duval
Walter Dominguez
Level 1 Expert
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
