Question about Grilling
Hi, I have a year old 12395 BBQ. Last week when using it for the first time I noticed a flame creeping down the rubber pipe, it appeared to be leaking gas from the side grill brass valve. I turned the gas off straight away and no damage was done. I checked all the gas unions/nuts and they all appeared to be tight. Also the gas 'popped back' as though it was burning in the venturi as well as the 'H' grill. Is there any suggestion you might offer as to why this has happened? Thanks. Kevin 01225 310 682 if required.
    Guru:
  • 1,051 Answers
Kevin, While I can't offer a suggestion regarding the cause of the problem, I'd like to stress to danger of a defective gas unit. A small LPG tank can explode with enough force to blow a hole through a wall. I'd suggest having it examined by someone qualified to service gas fittings.
Posted on Apr 26, 2010
I've had my grill for a few years and when i turned it on last night, i could barely see the flames and i had both burners on hi. I cleaned (took a wire brush) to where the flames get out and still...
You may have to recheck the tank for full. If you forgot to turn off the tank after the last time you used the grill, the tank could have leaked down. I always keep a spare full tank for just those types of problems. If the tank is full, then the regulator may have a problem. That grill should be able to get over 300 degrees.
Jul 07, 2011 | Weber Genesis Silver A Grill
Tip
How to diagnose a propane BBQ flaming at control knobs
WARNING: this test can be dangerous; do it only if you know what you are doing!
I turned on my two burner propane BBQ. The left side worked OK but flames started coming out of the control knob (front area) on the right, and the right side burner was not lighting.
This is obviously gas leaking out of the front area. If the flames go out when you turn the knobs off then the leak is after the valves, controlled ny the knobs. If the flames stay on and only go out if you turn gas off at the tank then the leak is at the pipe entering the controls. In my case the flames went out with the controls, so I looked underneath. I slowly turned the knob down and saw that the flames (therefore the gas) was coming out of the air regulator/entry hole. I knew at once that the pipe going to the burner must be blocked. Sire enough, when I removed the burners I saw that an insect built a cocoon in the pipe. Clearing it solved the problem.
on Jun 11, 2015 | Cuisinart CGG-200 All Foods Propane BBQ...
My Haywood H250FDP heater fires up for a few seconds and goes out. After several tries I get a Low gas pressure/No gas error code. I had my propane suppier come out and check. He tried to adjust the...
the flame sensor/thermo couple can be bad and or needs cleaning --carbon build up [one day old -one year old- 20 yrs old defective or damaged parts can happen any time]
Jul 04, 2011 | Hayward H-series Electronic Gas Pool...
We have a williams wall heater and it is 7 yrs old. The flame appears to creeps out ---we called for a heating co to review and they say to replace +/- $1700 or "Fix"---which I suppose is...
well having a service every year helps i would ask what they are going to do for 700 before they do anything I would think a burner would not cost that much
Dec 07, 2010 | Williams 3501922 (NG) Gas Compact Heater
Using a cadac burner with a skottel model extension 8304 , with no 24 Jet ( using a LPG 9kg gas Bottle - no Regulator ) flame is good on full ( good Blue Colour ) however on Low Flame keeps going out...
My experience shows me the old steam engine problems.
No gastight connections where they should be.
So not the specified Kilowatts output.
Think of the old fashioned flanges witht the artificial (synthetic) rubber gasket between them. And the flangebolts which held them together, all with the same torque momentum in kilopounds/meter.
Check with good quality leak detection foam and/or use your imagination.
Alternative: look for YouTube High Definition
video 'The Cadac Legend', as of August 15, 2011.
Dutch: ................... Trek in BBQ.
English: ................. Draught in BBQ.
Talkin' about airtight/gastight connections.
Oct 08, 2010 | CADAC Safari Chef Portable Grill
Hi, can tell to me why my 18-200 af vr lenss go
The "problem" is that the lens has a zoom creep issue. If you are the original purchaser, and the lens is under 5 years old, you may want to contact Nikon repair facilites in Melville or El Segundo to have it checked out.
Some users on forums have claimed that Nikon fixed the plastics ring that contribute to the zoom creep. Apparently, using a rubber band around the zoom ring will minimize the problem.
Hope this helps,
Andrew
May 14, 2010 | Nikon D80 Digital Camera with 18-200mm...
My Jenn air BBQ grill will not heat up all of
Couple things could be happening here. If you do exchanges, have you used more than one different propane tank since you've had this issue? This eliminates the possibility of a low tank pressure and a faulty tank connection. Next you need to look over the burners and the propane flow tubing. Spiders LOVE the sweet smell of propane and make their webbing inside the piping that get's the propane up to the burners. At your flow valves/On/Off knobs you'll notice that the propane shoots from the valves into a pipe with an air gap to gain oxygen. Look in there to see if there's any webs. Also should be a gap were that piping meets the burners, so you need to look there too. Depending on the age of the grill, you need to look the burners over. Corrosion & rust can cause the flame/propane holes in the burners themselves to cake up and close up causing much less flaming/heating opportunity. Also depending how much you've used it, it could be grease/dripping/sauce caked up over them too so they may need to be detailed/cleaned. It's not a pretty job, but grill maintenance that should be done every spring. When the burners get caked is when it's really fun and you need to remove them and clean out the holes with toothpicks. Jenn Air makes quality products, but being a BBQ and outdoors, it's just as vulnerable as any other to elemental and use issues. One last thing to check, some regulators (the disk shaped part right where the hose attaches to the tank) have another air mixture intake there with a screen on one side. Make sure there's no water in it and the opening is face down if you have one like that. Otherwise it's restricting the flow of the propane. I haven't seen one of these in a while, but they're still out there so check it too.
Jun 10, 2009 | Thane Q-BBQ Grill
GAS FLOW IS TO HIGH PILOT GOES OUT EXCESS GAS FLAME ON TAPPEN FU
Hi this could be a gas leak on the pilot i would get this checked out
Mar 17, 2009 | Tappan TGF320 Gas Kitchen Range
Grilling Logo
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
