Question about Cannon i70 Printer
Worked fine for 2 years. New OSX software. Downloaded new software. Printer feeds paper, print head goes left and right--no printing.
  • 4,041 Answers
Hi There
First put in new inks the old ones will not work it have run out dates on them.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
Print job disappearing and not printing
1. Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
2. Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.
3. Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.
4. Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
Canon-Specific Issues
5. Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
6. Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
7. Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
8. Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
Aug 19, 2012 | Canon Pixma Mp250 Printer
Just installed Mac OSX 10.6 and I can no longer print on the Samsung ML-1630. Downloaded from disc.
1: go to System Preferances 2: go to Print & Fax 3: Right Click the white box on the left 4: Click reset Printing System 5: reinstall software,
Mar 18, 2011 | Samsung ML-1630 Laser Printer
Hello, our C66 printer won't print. It has been unused for about 2 years, we've put all new ink cartridges in, downloaded the latest drivers, and nothing gets printed. You can go through all the test...
The most likely cause is the print head nozzles are blocked with dried ink and inserting new ink cartridges won't fix this problem. You need a new print head.
Print heads are not cheap, you may be better putting your money towards a new printer.
Jan 06, 2011 | Epson Stylus C66 Inkjet Printer
False "paper jam" signal prevents printing: My HP 2210 had been working fine. Suddenly, when I try to print, the paper starts to feed for a few inches and then stops. I get a "clear paper jam" error...
it's probably due to what i would call the print head blocker ( on your left handside of your printer head) that is broken . check it out! it also responsable to control how far goes the sheet before start printing.
Jan 14, 2010 | HP PSC 2210 All-In-One InkJet Printer
BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Jan 10, 2010 | Canon BJC-85 InkJet Printer
My Canon i850 accepts data from my pc. The printer head seems to go into action, but no print goes onto the paper after it goes through the printer. What could be the cause of this ? I have recently...
It could be a number of things
1: usb cable could be faulty this sending incorrect info across
2: could be something wrong with the actual print head try opening up the machine and see if you can move the carriage left to right by hand
also check if your able to print a test page from the unit itself to confirm it can print without the pc
Nov 10, 2009 | Canon i850 InkJet Photo Printer
Wont print
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head move to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head holder. Slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out of the tank.
5. Have several paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. My color and black and white print came right back!
Hope this helps.
Mar 17, 2009 | Canon PIXMA iP90 Mobile Printer
Info print 1140
when you go to the menu of the printer is the paper TYPE set correctly?
tray 2 should be letter ( if using plain paper)
tray 3 legal, label etc...
and tray 1 should be any
May 18, 2007 | IBM Infoprint 1140 Laser Printer
Top Cannon Office Equipment & Supplies Experts
Cosma Papouis
Cosma Papouis
Greg Cann
Greg Cann
Iqbal Husain
Iqbal Husain
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
