Question about Motorola Walkie Talkie 2-Way Radio
My sk710 was dropped into water is it repairable if so how is it done. the fastners I don,t seem to be able to remove.
    Scholar:
  • 157 Answers
Remove the battery and place unit in a warm place (not direct sun light). Drying time app 6 to 8 hours. Insert a replacement battery fully charged. Good Luck.
Posted on May 14, 2010
How do i replace the water intake valve?
Brand? Model number from serial plate. This like asking how to open a door. But is it a car door? House door? Is it a door.
Im sorry but could not manage myself.
Disconnect fill hose, there is your valve :-) the thing that the hose is screwed on to. Remove the top cover for front loading machine. Back cover/side panel for top loading machines. Locate valve. Unscrew fastners, or loosen fastner clips and replace it
Feb 13, 2016 | Washing Machines
Tip
Avoid dropping nuts and bolts out of your socket, or wrench!!
How frustrating is it , when you are trying to start a nut, or bolt, in a tight area, or in a recessed area, where fingers don't fit? All you have to do, is tear off a small piece of paper, wrap the head of the nut, or bolt, and firmly push the fastner into the socket, or wrench. Not only will this keep the fastner snug in the tool, it will save potential hours of recovering lost fastners. Good luck...Coop
on Oct 06, 2010 | GMC Sierra 2500HD Cars & Trucks
Have a 94 Camaro smokes white first start it and its raining after it warms up or I run it a lil bit it quits smoken. It runs good and don't seem to have any other problems
Sounds like your head gasket is cracked letting radiator fluid into your pistons. After it runs a little bit the water will dissipate. White smoke means you are getting water into the piston areas. Better repair ASAP before major damage is done. Will cost you big time if you don;t get repaired.
Apr 21, 2015 | 1994 Chevrolet Camaro
How to I clean between the glass door panels
Why? Mine looks to be almost a "sealed" panel, similar to the sealed Thermopane for windows and Doors, only the outside surfaces can be cleaned. If there is a decorator cover, that can be removed via the surround and remove. But I'd leave it alone. Consider it's age, your age, when will you move or not move, when or if you will replace it, or remodel. If it's a critical issue, I'd look for a nice looking used replacement door.
Mar 03, 2015 | Ovens
Dropped in water
DON'T try to switch on the camera. Remove the battery and after drying it from the outside, put it in a bag of rice till you can reach a repair centre.
Just google on camera or Phone dropped in water and read what the repair centre(s) have to say about that.
If it was very clean water, and the camera is not expensive enough to bring it to a repair centre, you could try staring it up after a few days in the rice, but still a chance the water already had don enough damage. Or while switching it on, permanent damage can occur because voltages can reach places the should not be. The minerals in the water can build bridges that will bring the damage.
I wish you wisdom and a little luck.
Jan 12, 2014 | HP Cameras
1993 Ford E350 Clubwagon Fuse Location
Under dash next to steering wheel (left) behind a panel that has two twist out plastic quick release fastners under the dash that you remove to drop the panel down and access the fuse center.
Apr 03, 2012 | Ford E-350 Cars & Trucks
Buick Park Avenue 1998 head gasket repair the mechcanic said it has blown head gasket and the engine must be removed to repair is this true
The engine does not need to be removed to replace the head gasket on your engine. More than likely it is an intake gasket that failed and showing the typical symptoms of a blown head gasket. If the intake gasket repair is put off long enough, it can turn into a blown head gasket and I've only had about a 50% success rate replacing the head gasket. They usually work fine for a few months, but the oil and water mix causes the oil to lose it's lubricating properties and even after fixing the cause of the problem, the damage may already be done to the engine bearings and the engine may knock later on down the road. You may want to get a quote on a used replacement engine if you plan on keeping the vehicle for a while and compare to the price of fixing it. In the long run, it will probably be a better solution.
Jun 06, 2011 | 1998 Buick Park Avenue
Remove hood insulator blanket
carefully pry the black plastic fastners holding blanket away from hood. these fastners snap into a bracket attached to the hood replace by inserting into the original hole
Dec 30, 2008 | 2004 Cadillac SRX
Door Handle repair
The fastner must be loose. Remove both set screws remove your handel. Then tighten the fastner. reinstall the handel and tighten your set screws. let me kniow if this helps
Aug 18, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Radio Communications Logo
214 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
OBHighflyer
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
