FixYa.com
Tags:
Hawking Networking Switch
Hawking HFS5t
posted by Quick fix on Mar 24, 2008
cat5e comes from my router to a wall plate. If I plug my HP printer directly into the wall plate, my computers see it on the network no problem. If I instead plug the HFS5T 5-port switch into the wall plate, and the printer into the switch, the computers on my network no longer see it. If I try to ping it I get some kind of destination unreachable report on my pc. Ideas?
My router is a DLINK running DHCP.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 28, 2008
Helpful (85)
edhall
Rank:Guide Guide
Rating: 91%, 7 votes
Try resetting the switch back to its default configuration. It sounds like you have a routing issue within the switch causing your printer not to be seen by your pcs.
Can you connect a pc to the switch just to see if you can ping your printer from there?
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Networking Hubs and Switches problems?
at-8624t
how to give an ip address to a... Answer This...
N-tron 9000 problem.
I have an N-tron 9000 that has... Answer This...
ignition switch
lucas 7 SA seven pin need... Answer This...
can't use winchat
hi, when i am trying to... Answer This...
my renter messed up the...
Got a call from a tenant that... Answer This...
Repair Service
Find Networking Hub and. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
