Question about HP Wireless Optical Mouse Sl/Blk With Scrolling Wheel (323616001)
HP Wireless 3 Button Mouse (KY620AA) sluggish movement out of nowhere not all the time but once in a while. I have Windows 7 on a HP Elite i7 box with tons of speed. The mouse works find for a while then just starts locking up and will barely move. I can then pull it off the mousepad and put it on my desk and it works fine. I've done batteries/different mousepad/Reinstall everything. Its an off issue thats annoying. HELP!
yooperbud
  • 8637 Answers
SOURCE: HP 3 button wireless optical mouse
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 20, 2009
  • 6 Answers
SOURCE: Mouse Issues
There is a light/button on the USB plug. After inserting the USB key press that button then immediately press the connect button on the bottom of your mouse.
Hope this helps fix your problem.
Posted on Oct 05, 2008
micromend
  • 748 Answers
SOURCE: the cursor on my laser wireless mouse won't move
You need to sync the mouse with the USB receiver. They'll be a similar button on the receiver. Push both at the same time.
Posted on Apr 07, 2009
SOURCE: GM323AA HP Optical 3 Button Wireless Mice
I have the same mouse. Make sure batteries are good. Then plug in the usb receiver. On the receiver, press the green led light, then press the connect button on the underside of the mouse. they should connect.
Posted on Apr 08, 2009
sales99521
  • 62 Answers
SOURCE: I have an HP wireless mouse Model Number MORFD7UL.
After you put new batteries in did you synce the device?
If not you must sync the device, usually its as simple as hitting a button on the reciever (the thing that goes into the computer) and then hitting the button on the bottom of the mouse. try that and see if it helps.
Steven.
Posted on Apr 16, 2010
Logik wireless scroll mouse
The mouse is listed as working with Windows 7 so you shouldn't have any problems using it in Windows 8.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
Wireless Optical Mouse Mi-4150K doesn't connect to pc
windows 7/vista :
-step 1 :Press the windows button (start button).
-step 2 : In the search bar type device manager.
-step 3 : Open the device manager.
windows xp/2000 :
-option 1 for opening the device manager :
-step 1 : Press the windows button (start button).
-step 2 : Open the control panel.
-step 3 : Open the "System properties".
-step 4 : Click on the hardware tab.
-step 5 : Click device manager.
-Option 2 for opening the device manager :
-step 1 : Press the windows button (start button). -step 2 : Select "Run"
-step 3 : Type the following into the text box "devmgmt.msc"
-using the device manager :
-step 1 : Once the device manager is open, click on "Mice and other pointing devices" or "other devices" (if prompt).
-step 2 : In the newly open menu, if there is a "?"right click on it and press update driver.
This should almost force the computer to recognize the hardware plugged into the USB port.
Hope this helped!
Nov 06, 2013 | Trust Wireless Optical Mouse Mi-4150K
When ever i move my curser on the screen the the scroll button comes on how can i get rid of it
Troubleshooting a mouse that scrolls up and down uncontrollably depends on various factors. Possibilities extend from the class of surface to hardware problems or configurations.
Identification
A variety of laptop mice exist.
A mechanical mouse uses a hard rubber ball that rolls with any movement of the mouse.
An optical mouse uses an LED sensor to detect movement.
An infrared, cordless mouse requires and relays a signal to the mouse port found on the laptop.
The base of the trackball mouse remains stationary, while the trackball sitting on top of this mouse reflects all movement.
Function
A mouse depicts a device that controls the movement of the cursor or pointer on a monitor or display.
Product
Several reasons exist for a cursor to uncontrollably scroll up and down on a display.
Static electricity often initiates wild cursor reactions.
To solve this, use pre-moistened computer cleaning wipes to help control static electricity and clean electronic surfaces.
Bad batteries can trigger impromptu cursor movements in a wireless mouse.
Electrical interferences can also produce the scrolling effect. Radio, wireless or electrical objects may require removal from close proximity.
The mouse needs to stay in range of the receiver, meaning near the Laptop
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
hope this helps
Sep 25, 2012 | HEWLETT-PACKARD HP Smart Buy ProBook 4720S...
Hp mouse clicking two times when i am only clicking once
I have had the same problem with my Logitech wireless optical mouse and it has always been an indicator that my mouse's battery is low or almost depleted. If you have a fresh battery and it is still behaving the same way then the contacts under your "left click button" could be wearing down or malfunctioning. Also there are some basic mouse control settings found under START-->Control Panel -->Hardware and sound-->devices and printers-->Mouse
Aug 09, 2012 | HP 3 Button PS/2 Optical Mouse
In windows 7, I can't figure out how to turn "tap to click" off. There is no tapping tab. Can you tell me how to perform this task?
Step 1: To turn off the hover option on your Windows 7 laptop, click your Start button (bottom left of your screen), then type main.cpl in the search box and click Enter on your keyboard. You can also go to your Control Panel, click Hardware and Sound, then choose Mouse beneath Devices and Printers.
Step 2: When the Mouse Properties box opens for your trackpad, choose the Device Settings tab to the far right, then click the Settings button below Devices.
Step 3: Double-click the word Tapping (or click the plus sign in front of Tapping once) in the list to the left, then uncheck Enable Tapping. Click OK for both boxes, and you're done. Now you can click when YOU want to click, not when your mouse decides to.
Jun 22, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Installing wireless mouse on Windows 7 Laptop
connect to the internet with your laptop and then plug in your mouse,windows 7 will automatically find the driver for you :)
Mar 07, 2011 | Computers & Internet
I have a samsung np-nf110/nf210/nf310 , os is windows 7 starter. i wanted to use my HP wireless optical mobile mouse but it doesn't seem to work or i dont think it connected. batteries are brand new and...
we dont do Samsung here, its HP
but HP mouse with no model stated, is impossible to be accentuate.
its a wireless mouse right, you left only small hint.
battery powered wireless mouse ,.by HP
windows 7
wireless mouse, HP and Samsung.
that takes 2 working drivers to make that work. both HP
the USB side and the mouse side.
HP does not support this on non HP computers so windows 7 is the only hope, MICROSOFT PLUG AN PLAY
you must be connected to the internet or its all just a wasted of time,
do so.
then plug both those things in.
the PC goes Dingdog sound telling you its found a new USB device.called wireless mouse HP, (no model stated)
then tries to find a driver on the web, MS servers for that.
if it can find one, then good luck, doing that. as the HP drivers will not like your PC
as here, if this is possible at all.
https://h30434.www3.hp.com/
Jul 05, 2017 | HP Wireless Optical Mouse
Recently downgraded to windows xp from vista, Atheros wireless will not turn on automaticcal when computer is restarted. At the windows loading screen, the wireless light turns blue for 3 seconds and then...
I had this problem too. You need the HP Wireless Assistant. Download it here- ftp://ftp.hp.com/pub/softpaq/sp36501-37000/sp36770.exe
Once installed, open the HP Wireless Assistant and click Properties button. Check the box next to "Independent controls for installed wireless devices." Then click "Turn All On" button. On next boot it will be enabled!
Sep 07, 2010 | HP Computers & Internet
64-bit Windows 7, logitech keyb+mouse
I can't find your keyboard, but there again I don't have all the details so, if you'd like to start here :-
http://www.logitech.com/en-us/support_downloads/
Enter the required options to get to your particular keyboard, you should be able to find out if there's a relevent driver for you.
May 10, 2010 | Logitech Wireless Access Duo Optical...
Programing
Hi!
First install the driver for your wireless keyboard. Then connect the USB for your wireless. Make sure that you already have batteries in your keyboard and mouse or in other cases fully charged if rechargeable. Wait for it to be detected by windows. Once detected, on the USB press the connect button then followed by the connect button on the keyboard then the connect button on the mouse. Then that is supposed to work already. Hope this helps.
May 02, 2010 | Microsoft Wireless Desktop Elite...
Computers & Internet Logo
175 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
