Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
I have a Craftsman 1 hp, 3 gal air compressor model #921.153101 that wont pump air, the motor runs fine, the hose is clear what can I do to get it running?
    Problem Solver:
  • 12 Answers
Remove the air filter and see if the inlet is sucking air if so the unit is pumping,if not the valves could be bad or the piston is broken.
Posted on Apr 29, 2010
Air compresor Craftsman 921.153101 it spound like is one but it wont run at all. It sounds like the motor is stuck
if its belt driven ,unplug it(safety first)remove the belt and try to turn the pump by hand.if the pump turn plug it back without the belt. and try it .if the motor doesnt run.check the contacts on your pressure switch.if they are ok and try again.if not you need a new motor.if the motor ,the pressure switch contacts,and the pump are fine.put the belt back back on bleed your tank to zero with an air gun and try to run it.if it work well till it cuts of check if your bleeder release air.you might have pressure stuck in your pump.the compressor needs to release pressure for a soft start.hope this help!
Apr 17, 2011 | Craftsman 3 gal. Air Compressor, 1 hp,...
Problem with the craftsman 30 gal compressor 6 hp vertical oil free. motor or compressor will not engage, when turned motor starts for a second and sound slow then pops the breaker
sounds like you are not getting enough voltage to run the compressor if you are using an extension cord check your manual to see what gauge it should be depending on how long it is if you are plugged into a wall outlet then is the compressor the only thing that is running on the circuit if some thing else is running then you may be overloading the circuit.
Feb 24, 2011 | Craftsman 15 gal Air Compressor 3 hp UMC...
Craftsman 3 Gal. Air Compressor 1 HP Hortiz
Does it run? Does it stop running? Does the pressure gauge read anything at all? Is there a regulator on it? Can you take the reg off? A bunch of things to check, get it running and let me know what you find, and I will try to tell you what's next.
Feb 27, 2010 | Craftsman Air Tools & Compressors
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is building up
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing.... also drain the tank
Dec 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have a craftsman 6.5 60 gal horz compressor.
i have the same piece of junk, iv rebuilt it 3 times in the past 5 years always a piston rod snapped and then it was running on only one. they are built like ****. anyhow I finely got smart and bought a cast iron pump thats not only quieter but puts out twice the volume of air in half the time. it took some work but it was well worth it costing under 200.00. the rebuild kit from sears will cost over 100 and it wont last. the one from sears is a direct drive pump and you will be told no one makes a direct bolt on but all it takes is cutting the aluminum housing away from the motor and welding a pin or bolt to the end of the shaft and putting a pully on it, you will also have to turn the motor to the side but let me tell you this was the best move i ever made. you can pick I bought my new pump from a place called heavy dudy air in ga. 877-447-2485
Oct 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Sears craftsman 3 gal/1.5 hp air compressor won't run
are you using an extension cord? if so, plug the compressor into a wall socket, if it fires up fine then your extension cord is too long or not heavy enough - other problems could be a bad start capacitor, a loose connection in the pressure switch, or a bad switch
Aug 15, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air wont built in tank, motor runs fine
As the pump is running try spraying all the fittings with soapy water and look for bubbles. Hope this helps. Good luck.
Jul 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
585 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
