Question about Targus Chill Mat PA248U Laptop Cooler
Chill mat notebook cooling chill mat will not turn on
  • Nimelen Apr 27, 2008
    I have a Targus Tornado Chill Mat. I love it, but it stopped working after over a year of use, and I discovered that the cord is the problem after buying a new one and trying the new cord with the old mat... It costs $10.00 plus shipping to replace the cord, and I only paid $25.00 for the mat and cord! Any ideas about how I might fix the old cord?
The cable you get never works
Posted on Jul 19, 2008
I have 1 as well and it broke too. this is http://computers.pricegrabber.com/laptop-accessories/m/1754767/
right?
if its the cord's thats broken, its most likely the switch, more specifically the soldering where the wire connects to the switch is prolly broken. i just sawed my switch open w/ a knife, and took a look. now if a wire is loose in the switch, u can either solder it back on, or (in my case i always have the fan on anyway cuz of my **** dell computer overheating) rip the wire off the switch completely and just connected it w/ aluminum foil.
Posted on May 23, 2008
2 Suggested Answers
SOURCE:
SOURCE: Targus notebook cooling chill mat.
I have the same problem, and I looked inside to see the cause- the interior part for the power is poorly made and comes loose. That's the reason for the one fan not working and it getting weak. Sometimes wiggling the cord or trying to stabilize it will help. But, as I learned the hard way, it will eventually break. Its a poorly made product, and I've had mine about 4 months now and it completely broke today. I opened it and did my best to stabilize the part, but... it will break. As best as I can tell, its a poorly made product and there is no permanent solution.
Posted on Oct 24, 2008
What are the other ports used for, and can I use them to run the fans?
Do you mean the USB-ports on your laptop? If so, than yes, you will need one free USB-port to connect the Chill Mat to.
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
The little insert in the usb port on my targus dual fan chill mat has become loose. How do I re-insert it and keep it from becoming loose again?
Tawny, If port still functioning, use 2 part epoxy to secure port, be care, no glue inside port.
press the helpful button
Targus chill mat won't work
it is definatly either a wiring issue or a cpu issue
Mar 18, 2014 | Targus Chill Mat PA248U Laptop Cooler
Lost the targus notebook chill mat power cord (usb from computer to the mat). Where can I find a replacement?
hi this can be purchased from somewhere like radio shack specs are Output: 5V 2000mA, centre is + positive so really just your standard adaptor will do, this also comes from the targus site hope that helps
Oct 02, 2010 | Targus Chill Mat PA248U Laptop Cooler
Targus Chill Mat. I keep getting error with windows 7 that the device is not working properly. It operates but an error keeps popping up every 10 seconds. So I can not use it. What is the fix?
Belkin makes a surge plug that has usb powered ports.
this is a Gr8 option it takes the poering off the pc.
this should fix ya up.
Good Luck
Happy Computing
Jan 10, 2010 | Targus AWE19US Chill Mat XC for Laptops
Targus Chill Mat Fan On Fritz
The fan rotor is stuck due to accumulation of dust. Take out the fan and clean it. Put a few drops of alcohol or lacquer thinner on the rotor/bushing assembly while manually turning its blades to loosen the hardened dirt until the fan freely spins like the good one. If it does not work, replace the defective fan if spare is available.
Aug 19, 2009 | Targus Chill Mat PA248U Laptop Cooler
Targus notebook cooling chill mat. One fan has stopped running after less than 2 months. Can you help
Sep 28, 2008 | Targus Chill Mat PA248U Laptop Cooler
Where is the on/off switch for the cooling chill mat?
if it a normal chill mat and power by USB, there is none.
If you want me to look at it further, provided make and model.
May 06, 2008 | Computers & Internet
Computers & Internet Logo
406 people viewed this question
Top Targus Computers & Internet Experts
Raj Patel
tony wahlman
tony wahlman
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
