Question about Panasonic ToughBook 52 Notebook
Where can i find a Motherboard for a CF-52? Are the CF-52 have a base model MB or is everyone different?
  • 1,183 Answers
You can download the drivers from the following website. Select Driver chipset in the first drop down for motherboard drivers.
Yes, different CF 52 have different motherboards depending upon the processors and video cards in the configuration.
Thanks for using Fixya
proton
Posted on Apr 26, 2010
How to disable mouse pad double tap
On all Panasonic Toughbook models, if the Touchpad driver is
properly installed then you can disable the "TAPPING" feature.
Check under device manager. If the driver says PS2 Mouse,
then you need to locate your touchpad driver. Otherwise
locate the advanced setting under MOUSE under the control
panel and find "TAPPING" and un-check to disable feature.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
May 10, 2014 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
I want to install windows xp on my panasonic cf-52 that has vista
Drivers for all Panasonic Toughbooks can be found:
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
Select your Toughbook Model first,
then select your operating system (XP SP2).
Good Luck,
Regards,
Panasonic Canada Toughbook Authorized Dealer since 1989
Feb 10, 2014 | Panasonic Toughbook CF-51 Notebook
Swapped out hdd cf-52 nothing happening
When you swapped out the Hard Disk Drive
of the Panasonic Toughbook CF52 it is very
importatnt that you did not "hot" swap the HDD
but that you turned off the unit with a full shutdown
and unplugged it as well.
Once you removed the Hard Disk Drive (HDD)
I am assuming that you replaced the drive with
another drive that had a proper operating system
already installed. If not, then of course nothing
happened since you replaced the HDD with a blank
or unformatted HDD.
One way to verify if the replacement Hard Drive
is recognized by the Toughbook is to go into
the BIOS by pressing the F2 function key and
checking the size or capacity of the replacement
Hard Disk Drive. If it shows the proper value,
then the HDD is recognized at the Hardware Level.
If it shows HDD as None or Zero then the replacement
HDD is NOT recognized and you have to try a different
drive which is functional.
Good Luck!
Regards,
Nov 08, 2013 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
CF-52 V Drivers
We couldn't really identify which drivers are missing. Here's what you can do. Boot to safe mode and check the device manager. Uninstall the drivers with problems and restart your computer. After that, install the drivers by going to the website of the manufacturer and download the drivers from there.
Use RadarSync if you want to update the drivers. This software is an automatic PC Updater (Drives).
David
Apr 03, 2013 | Panasonic Toughbook CF52 Notebook
How do you do a master reset on a panasonic cf-52
You can reset the password on your Panasonic CF-52 using two different methods. You will need to open up the back cover of your laptop. Now, pull the CMOS battery cell from your motherboard for twenty minutes and then put it back. This should clear the memory. You can also clear your password with jumper settings. Find the jumper on your motherboard named clear CMOS, it has a 3 pin.(1-2-3) Put the jumper in the 2-3 position and then again put it in 1-2 position then check.
Jan 20, 2011 | Computers & Internet
Where do i attach a 802.11 g interally on a CF-27 toughbook?
Internal wireless adaptors are not made for generic use. Each motherboard used a different design to it. You will have to use a USB type adaptor.
Feb 25, 2009 | Panasonic Toughbook CF-27 Notebook
Keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Jan 04, 2009 | Panasonic ToughBook 52 Notebook
Where to buy cf 52 motherboard
www.laptopparts.com would be a great place to start. CF-52 is a Panasonic Toughbook laptop.
Dec 30, 2008 | Computers & Internet
Panasonic ToughBook 52 Notebook Logo
649 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
