Question about Polaroid TLX-01511C LCD TV
The display goes white to red to black, after a few seconds
The display has gone dark, black. On startup, the display lights as normal while the Polaroid logo displays, but just goes blood RED for a moment and then BLACK after maybe 4 or 5 seconds. Using the remote, it apparently still changes channels and I still hear audio, so it appears to be just the LAMP or LAMP POWER SUPPLY which has failed. I can find NO information on the guts. I tried pulling the back cover off with no luck. With all the screws removed, the back is still so tight (maybe glued!) I was afraid I would break it if I simply tried to pry it apart. Is there a trick to opening the back? If I could get it open, at least I could check the lamp power to see it is bulb or supply. I can replace parts myself if I could find a source. I checked with Polaroid about out of warranty repair and they quoted a replacement cost instead, of more than it cost when I bought it new, and that was for a refurbished one with only a 30 day warranty! And they wanted the failed unit back. OK, so I am looking for information on replacing the lamp or the lamp power supply, where I can get parts, a service manual, SOMETHING. I'm tempted to just buy another, swap the internals and then attempt fraud by trying to get it repaired under the warranty of the new one I buy, but that is NOT exactly honorable, and I'll bet there are internal identifiers which would expose my plan anyway, so I'd probably lose. I would much rather fix it myself than commit fraud...
  • Polaroid Master
  • 8,457 Answers
U remove the base yet?Check all screws,remove every screws small or large.Will get this ****** open.I diagnoise ur tv problems,the LCD inverter board is dead.This board help to get LCD backlight to light to get light to the LCD screen make the Tuner board to get signal to get the picture throught to the LCD screen.This LCD inverter board is long shape board.Replaced this board u will get the backlight to the LCD screen,back and get a picture.The Websites like Shopjimmy.com,Ebay.com.U can able to buy a reburbish LCD inverter board for the replacement.
Posted on Apr 26, 2010
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Display turns dark pink for few minutes and goes
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 23, 2013 | Eiki EIP-5000L 5200 ANSI Lumens DLP XGA...
One of the two monitors will cease displaying screen image and begin rotating between a BLACK/WHITE/GRAY/Primary Color Bars every other second following a few minutes after start up. Have tried Restar
It might be the input from the graphics card. Try swapping the two monitors' feeds to see if the problem is with the monitor or the card. The monitor seems to be going into a screensaver mode since there's no signal. The flashing light could mean there's a power supply problem, or no signal.
Oct 15, 2017 | DoubleSight Displays Computers & Internet
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
Need factory wiring codes for a 1999 jeep grand cherokee
battery red/white
accessory white/red
ground black
LF - light green/green
LF + light green/red
RF- light blue/ black
RF+ light blue/red
RR- tan/dark green
RR+ white/violet
LR- white/dark green
LR+ dark green/white
Dimmer orange
This wiring is for the standard audio system
Sep 17, 2010 | Car Audio & Video
After working normally for several years, my Inspiron 1100 display went dark but will come on normally if I press Fn+CRT/LCD BUT ONLY FOR 1 OR 2 SECONDS then goes dark again. Tried holding F8 during...
there is a ribbon cable going from the lower [keyboard unit] to the upper unit [display] that has been going bad over time. or the display panel backlight is bad.. you might be able to save old betsy by taking her to a laptop shop and see what they can do..goodday
Nov 09, 2009 | Dell Inspiron 1100 Notebook
Viewsonic monitor goes black one second after startup screen boots up. Fix for this? thanks
plz log in safe mode and then disable the display adapter from the device monitor then log back normally and check whether problem is solved or not
Apr 29, 2009 | Computers & Internet
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
Polaroid TLX-01511C LCD TV Logo
196 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
