Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
Maytag spiner arm removal
Pretty convinced I need to remove the spinner arm and clean it out but I don't know how. There are no screws.
It's a Maytag Jetclean Quiet Pak.
thanks, jo
  • Maytag Master
  • 43,501 Answers
Most of them just pull down and off. the little plastic jigger that holds them often breaks, so I would order a new one first before forcing it...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " Great tips, will get the handy husband on this asap........thanks " -
Posted on Apr 27, 2010
Why is my maytag neptune mah3000aww making a loud noise in the spin cycle
Could be the berrings need to be replaced or possibly a broken spinner support assembly which is located on the outside of the inner stainless steel basket. Both of these repairs are costly and not worth paying for service to repair them, but if you are mechanically inclined and VERY patient you can probably make the repairs yourself. I'm in the middle of mine and very hopeful at the moment. Lots of information on youtub for berring replacement, but I didn't find much on spinner support replacement. I did figure out how to remove the spinner support and clean it. Mine is still in good shape.
Best of luck! :)
Jun 20, 2014 | Maytag Neptune MAH5500B Front Load Washer
Do I access the tub area from the front panel or the top?
The 5500 Neptune washer and all predecessors are accessed from the front. by removing the 2 hinge screws, and the opposite 2 screws. The front goal post panel can then be removed, then the door can be lifted off. Maytag made a 1 piece tub and a removable front tub cover. Once the tub cover is removed by pulling all the tension clips you can remove the stainless spin basket one of 2 ways, either remove all 3 of the basket tumblers, then the 3 basket bolts, then the basket can be removed leaving the spinner support behind, or you can remove the rear panel, then the main pulley, then tap out shaft with a 2X4, this will remove the basket and spinner support together. You have not described the nature of your leak. Pleazer Appliance...
Apr 27, 2014 | Maytag Neptune MAH5500B Front Load Washer
Call the Maytag man because I dropped a toothbrush down dryer lint vent?
You can do this yourself.
What is the complete model number of your unit?
Dec 03, 2012 | Maytag Dryers
There is no water getting to the top end of the second rack plz help
Hello, welcome to FixYa.
This procedure applies to most modern Whirlpool, Maytag, KitchenAid, Kenmore, Amana, dishwashers...to name a few. There may be subtle differences between them such as options, rack design, lower spray arm appearance etc.
There likely is a blockage in the filter/screen and chopper assembly below in the sump well, it's just not obvious/visible. The place to look for a remedy is the wash pump area, you`ll need to follow these steps to clean it.
This is why the top rack is most effected, poor water circulation.
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rear tab, i.e.
b ) Then twist the feeder to the right ( clockwise ), i.e.
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the cover
i.e.
Now you should see the chopper and screen assembly,
it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part.
If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Aug 15, 2011 | Maytag MDB7809AW Builtin Dishwasher
Maytag eq plus, not cleaning properly, seems the
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
h
Feb 28, 2010 | Maytag MDB7100AWB Dishwasher
Maytag model dwu9200aax pieces of plastic and cloth clog some of the rinse holes on the spinning rinse part..how to take apart rinse arm to clean it?
The top spinner part can simply be pulled off by grasping it near its hub and pulling downward. Push it back on and push in the locking clip in the center. The bottom spinner can be removed, First unscrew the center column. Hold the spinner with one hand, turn the base of the center column counter clockwise. Then lift column off. Then the spinner should lift off of the keyed white plastic base. Underneath it, on the neck off of which you lifted it, are two plastic washers that form a seal (supposedly). Good to clean these to make spinner rotate freely, but be careful not to break them taking them off. If you want to go farther in, there is the point of a strange shaped plastic nut sticking up into the base of the column. If you remove this, and the 6 torx screws holding the strainer cap, you can get it all out to clean it up (I had bits of plastic bag in the slots of a 4-armed thing that apparently sprays the filter screen), and scrub the washer in the bottom. Remarkably yucky down there in a 10 year old installation...
Nov 11, 2009 | Maytag MDB6650A Built-in Dishwasher
Removal of spinner (it turns the spray arm) on top of pump housing.
If your talking about removing the bottom, main spray arm for the MDB7100AWB, in the middle there's the little hole with a plastic cog, button, whatever you want to call it that you can grab in pull up and spin, but this is just a spray jet and has nothing to do with removing the arm. But, around that hole in the middle is a disc that is somewhat flat and only sticks up about an 1/8 of an inch from the arm, this is what you need to unscrew to remove the arm. It almost looks like part of the arm (especially if it's caked with detergent), but it's actually the screw fastener that holds the arm on.  Just muscle that disc, turning counterclockwise, and it should unscrew, then you can remove the main arm unit.
For the top arm, it just pulls straight down and pops out.  You feel like it's about to break, but then it just pops out.  To put it back in, it just snaps in when you push it in.
Hope this helps.
May 26, 2008 | Maytag MDB7100AWB Dishwasher
Dishes not getting clean
In the center of the arm is a screw on cap. It looks like it's part of the arm, but the round center screws off.
Jan 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Jul 31, 2007 | Jet Tech Systems STEALTH Dishwasher
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
321 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
