Question about Microsoft Wireless Desktop Elite Keyboard/Mouse 2090265223
I spilled water on my MS wireless multimedia keyboard 1.1. Dried it out. A few of the keys don't work. Is there a fix?
    Scholar:
  • 62 Answers
This depends on how good you are at opening your keyboard. Inside the keyboard is a thin plastic film that has contacts for the keyboard to make contact with. They are very sensitive to water. If you can take the keyboard apart carefully and can get to the plastic file and make sure its dry. (which i am guess its still got water in it cause they usually do) Then you can save your keyboard. Other wise sorry buy another one. The way i look at it is you are probabley going to be buying a new one anways what have you got to lose :)
I had the same issuse i got all keys working again except my f3 button. and i use it all the time so i adventually had to buy another keyboard. However if you like to take things apart :) now is a good time.
Hope this helps thanks
Steven.
Posted on Apr 27, 2010
Four keys in Belkin wireless keyboard are not working
If only specific keys are not working, something is obstructing those keys\' pickups which are located immediately beneath the keys. This is almost always caused by food debris or liquid spillage as dust doesn\'t provide particles big enough to cause issues.
If those four keys feel "funny" when being pressed, it\'s almost certainly a physical obstruction. If they feel "sticky" it\'s always a liquid spill. If you don\'t recall spilling anything over the keyboard, use a can of compressed air (found at office supply stores).
Turn the keyboard long side up, with the keys leaning slightly downward. Place the air nozzle close to the intersections of the keyboard, starting at one side and work your way to the other side, using short bursts of air. Repeat for every row of keys. Pay special attention to the four that do not currently work.
You\'ll probably see lots of junk fall out of the keyboard. That\'s good, if so--I would then retest the keyboard (no need to reboot the computer). That should fix it--if not, you may have to resort to pulling off the keys that don\'t work. The next possibility would be broken key hinges, but that\'s beyond the scope of this reply.
For liquids, cleaning is hit or miss. If left long enough, liquids will eat away at the circuits, or provide a short circuit and kill the component. Since only four keys are affected, I\'m really leaning towards food debris, but if you did spill a liquid, you can disassemble the keyboard and clean up any residue under and around the keys. Probably best to use rubbing alcohol and a q-tip for that--but if you\'re not comfortable taking stuff like this apart, it might be time for a new keyboard, or find a handy friend. Good luck!
Apr 07, 2014 | Belkin Wireless Keyboard/Optical Mouse...
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Few keys not working on keyboard
Should replace key board. Moisture and keyboards do not mix.
Jun 14, 2017 | Microsoft Natural Ergonomic 4000
I have spilled water on my laptot and the keyboard doesn't work anymore. I have connected an external keyboard now however, I cant switch on the wireless capability. Does anyone know a way to do t
There may be a switch on the side of the laptop that turns the wireless on and off. Also try pressing and holding the fn key and pressing and releasing f1 or f2. The water spill may have killed the wireless card also. If you still can't get it working, then purchase an inexpensive usb wireless adapter. This will plug into an available usb port and will give you wireles capabilities. You will need to replace the keyboard as well as it was obviously damaged by the spill. Check on ebay, or contact the manufacturer for a replacement.
Hope this helps!
Joe
Mar 25, 2012 | Fujitsu Siemens (AYU0N1090ED00103) PC...
Spilled water on keyboard. a few keys don't work
If this problem occurred recently you might still be able to save the keyboard. However, it is a painstaking method of popping out each of the keys that are not working and cleaning them off (preferably with some contact cleaner) and making sure that there is no corrosion trying to form due to the moisture. Be careful when prying up some keys as some keyboards (especially laptop keyboards) are hard to put back if you don't have the right tools or the know how. I suggest looking up keyboard removal techniques based on the brand of your keyboard/laptop.
Good luck...
Apr 17, 2010 | Computers & Internet
Keybd keys are sticking
Be prepared to buy a new keyboard... Remove AC and DC power before working on laptop. Many laptop keyboards come off with the removal of 1 to 5 screws from the bottom. Some, however, require the palm rest to be removed, then a couple of screws that hold in the keyboard. Be careful when removing and replacing cables.After removing keyboard, rinse with water and let dry thoroughly before re-attaching and powering up. You cannot remove individual keys, so don't try.
Apr 12, 2010 | Fujitsu LifeBook S6510 Notebook
My return key is not functioning on my apple keyboard.
Buy a new keyboard. They are cheap. One possible solution is to allow the keyboard to thoroughly dry and try it. You can pry up the key and look and see if it needs to be dusted out with some air, or cleaned of whatever was spilled on it. Perhaps alcohol on a Qtip on the moving parts. Not sure what "something" splashed on it. Root beer? Water? Big difference. I would visually inspect, try to dust, then clean with alcohol. Let it dry thoroughly and give it a shot. Short course, buy a new monitor. Good luck.
Mar 30, 2009 | Apple Macintosh Keyboard
MS wireless laser keyboard 5000
Go to the Hkey_local_machine\system\currentcontrolset\services\hidserv\parameters, ServiceDll parameter defines the path to the file hidserv.dll that is needed to make sound+\- key workable. I searched for that file on my computer and found it at C:\WINDOWS\system32\drivers\ , but ServiceDll registry parameter pointed at %SystemRoot%\System32\hidserv.dll, so I changed it's value to %SystemRoot%\System32\drivers\hidserv.dll, rebooted my computer and solved the problem;)
Nov 23, 2008 | Computers & Internet
Due to sugary spill, 4 keys not working on keyboard
Simply stated, yes.
If you plan to do that, in the meantime you could also run the keyboard under a warm shower for a new minutes and then hang it out to dry in the sun. I'm not kidding. It will probably, that is probably, work just fine after that so long as all the water has dried and drained out and its not an IBM mechanical keyboard.
Regards,
Worldvet
May 24, 2008 | Acer Aspire 5100 Notebook
Microsoft Wireless Desktop Elite Keyboard/Mouse 2090265223 Logo
126 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
