Sound problem mysound and audio is missing from my control panel how do it get it back. I also don't have any sound now
  • 38 Answers
If you're talking about Windows XP, the volume control is available from the Control Panel under Sounds and Audio Devices; place a check-mark by the Place Volume in Task bar.
If you don't have Win XP, you can try to reinstall your sound icon by going to Control Panel -> Add / Remove Programs, Windows Setup tab and then double click the Multimedia icon and place a checkmark on Volume Control. If it's already there, take the checkmark off, then click OK. Then go back in again and place the check mark on.
This will hopefully reset it.
Posted on Mar 24, 2008
The board don't any sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 16, 2011 | Computers & Internet
Sound driver is missing
if you are having problems with your sound
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps don
Mar 13, 2011 | Computers & Internet
Soundmax integrated digital audio missing
also
hope this helps
don
Feb 24, 2011 | Compaq Computers & Internet
Just moved and my speakers are not working. The green wire is plugged into. Thecomputer - am I missing something else? We have power in the speakers
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
hope this helps
don
Feb 12, 2011 | Gateway Edison Computer Speakers
I have creative sound blaster Live digital audio card .but now the driver cd is missing what can i do?
also
hope this helps
don
Feb 11, 2011 | Computers & Internet
I have asrock mother board, missing sound driever p4145gl.pls help
also
hope this helps
don
Feb 10, 2011 | Asrock P4145GL Motherboard
Don"t hear anything at all.
control panel sounds and audio devices,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow? right click re-install drivers
good luck
Aug 29, 2010 | HP (153147-001) Sound Card
No sound in the system
Did you check if there is an audio device in the Device Manager (from the Control Panel -> System) ?
If not, you probably need to install the right audio driver for your computer.
Jun 22, 2010 | Intel ESS ES1868F Sound Card
Missing icon
click 'control panel'
click 'Sounds and Audio Devices'
Check the box that says 'Place volume icon in the task bar'
Dec 11, 2008 | Gateway GT5404 PC Desktop
Mysound
Check the sound scheme via the sounds icon in control panel. If it says No Sounds, select Windows Default, if a pop up appears asking if you want to save the scheme, select NO. Then select a sound, such as Exclamation, then click on the Sound Play button. Also, should check Device Manager, to see if there are any yellow exclamation points in Sound Card, or if it is disabled.
Apr 29, 2008 | Creative Labs Sound Blaster Live! 5.1...
Open Questions:
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
