Question about Cosco 2-in-1 Sleigh 10121 Crib
One of the pieces that allows the crib rail to
I got this crib from a relative and one of the plastic lever pieces that locks the drop side rail in place is missing. Now I can't put the rail in up position. Can I buy one of these pieces? Thank You.
  • 4 Answers
CALL CUSTOMER SERVICE AT 1800-544-1108
Posted on Apr 29, 2010
I need the 2 plastic pieces that attach the drop rails
Certain parts are available only by calling Delta Customer Service directly at 1-800-377-3777 EXT 6221 Monday- Friday 9:00a.m.-5:00 p.m EST.
Or I can send you the ones I have just taken off my crib, when I converted it to a toddler bed. If you want me to please email me kristy.mahar@charter.net
Sep 25, 2009 | Baby Gear
Broken Hinges
Sounds like you have one of the cribs that was recalled for that very reason. They will send you the right parts for free to fix the 'drop side trigger lock' that was recalled, even if you didn't register the crib. This is their phone number: 1-800-816-5304,
This is the website http://www.deltacribrecall.com/
Hope that helps!
Jun 24, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Sorelle Allessandra Crib - broken plastic slide in side rail
Products America can not provide parts for the Sorelle cribs however they should be able to provide you with contact information for the company. You can call 800-205-9642 or 800-772-1041 and speak with a customer service rep who would be more than happy to assist you in contacting the company.
Jun 17, 2009 | Graco Ultra Deluxe 5-in-1 4605 Crib
I need a plastic part for a Nelson baby bed, that holds the rail
I need the pieces to go on the sides of the baby bed that lets the bed up and down.
Could you please let me know where I can go to get the parts for this>>??
Thanks,
Mary Adams
1474 Swindall Road
Troy, Alabama 36081
334-566-2900
Apr 11, 2009 | Baby Gear
Looking for teething rails for the Bethany James crib.
gud morning..maybe you can put a replacement of the plastic piece that slides or snaps on and covers the entire top of each side rail, you replace it by puting a cloths on it..and make sure that the child is safe.
thank you
Feb 20, 2009 | DaVinci Leonardo Crib
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Delta Luv Dutchess 2 in 1 crib
The front rail(drop rail) has a little plastic piece attached to it that reads "push".  This will be on the bottom.
Sep 01, 2008 | Delta Luv Delta - Baby Products 5-in-1...
The Dorel 3-1 convertible crib model # WM1633
Do not use this crib. This crib broke and caused my infant son of six months to get caught. He passed away on October 16th because of getting caught in this crib. I am trying to getting this crib recalled. Please Please do not use drop down cribs. They are entrappment devices for infants. 3 infants including my son have died in 2008 due to drop down side cribs. Please for your babies sake, take this crib back.
Jun 22, 2008 | Dorel Alexander
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Childesigns crib part needed
I have the same problem and I spoke to www.productsamerica.com at 1-800-772-1041 this morning and they said that the childesign is no longer in production as far as they know and no parts available. They also said no repair kits available will fit it. I am stomped as to whether I should just go out and buy another crib now.
May 23, 2007 | Childesigns Bellmont Crib
Cosco 2-in-1 Sleigh 10121 Crib Logo
172 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
