Question about IBM ThinkPad T21 Notebook
Boot up issues
When I try to turn my computer, during boot up it gives me this error message: the following file is missing or corrupt: \WINDOWS\SYSTEM\vgaoem.fon. What can I do to fix this? I have put a windows XP disk in, but the same message still pops up...
    Sergeant:
    Champion:
  • 277 Answers
Run cmos bios and configured boot device..first boot cd rom drive..
then reinstall/repair your os...
Posted on Mar 24, 2008
I HAVE A GATEWAY DESKTOP COMPUTER WITH AN ERROR MESSAGE SYSTEM32\NTOSKRNL.EXE. HOW DO I FIX THIS PROBLEM?
NTOSKRNL.EXE is missing or corrupt. Issue NTOSKRNL.EXE is missing or corrupt.
Related errors
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution
Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you load the last known good configuration.
This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section.
Microsoft Windows XP users:
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you reinstall Windows.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
http://www.computerhope.com/issues/ch000646.htm
Mar 02, 2012 | Gateway GT5026E PC Desktop
Tip
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Cause:
  1. Keyboard issue
Solution: Keyboard issue
This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Make sure the line pointing to the operating system and its drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648.
OS Loader v4.01
Attempt to check the hard disk drive for any errors by running the chkdsk program. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186.
on Dec 27, 2009 | Computers & Internet
Ntoskrnl.exe is missing or corrupt solution
Issue:NTOSKRNL.EXE is missing or corrupt.
Related errors:
Cause:
  1. Keyboard issue
Solution:Keyboard issue
OS Loader v4.01
Oct 01, 2009 | Microsoft Windows XP Professional
It keeps saying that ntoskrn1.exe is missing
It is pretty much crashed....hard. Might want to reload the OS. Yes you can recover from that, but it is not worth the time and frustration to do it...Provided you can afford to lose whatever you had on the primary partition (C:\) drive. Let me know if you need other asst. It is a little complicated to explain. How many machines is this affecting? All of your E-Machines?
Aug 13, 2009 | Computers & Internet
Error messages :system32\hal.dll missing or corrupt"
Looks like you might have to format your drive and reload windows from scratch,unless you can restore deleted files from your recycle bin
Apr 30, 2009 | Dell Microsoft Windows XP Home Edition
Bootup failure
Cause:
  1. Keyboard issue
Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
OS Loader v4.01
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
Dec 05, 2008 | Acer Aspire 3624WXCi Notebook
Error: windows root>\system32\ntoskrnl.exe
Related errors:
Cause:
  1. Keyboard issue
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 18, 2008 | Computers & Internet
How do I...
Related errors:
Cause:
Keyboard issue
Solution:
Keyboard issue
OS Loader v4.01
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
ACER DESKTOP COMPUTER
Related errors:
Cause:
  1. Keyboard issue
best regards wish u give me a good rate ^^
Aug 15, 2008 | Acer Computers & Internet
Missing or corrupt \system32\hal.dll
You didn't need to replace the hard drive if there is a missing NTLDR file, it just means that the boot sector is missing or corrupt. You can fix it by putting in your WinXP CD, and choosing REPAIR.(This is known as the Recovery Console and it's in DOS just to warn you...) Then you can type the following at the dos prompt: fixmbr - Fixes corrupt master boot record fixboot - Fixes corrupt boot sector bootcfg /rebuild - Fixes corrupt or missing boot.ini
Mar 28, 2007 | Western Digital Scorpio WD800UE 80 GB Hard...
IBM ThinkPad T21 Notebook Logo
155 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
