Question about Samsung DV219AG Dryer
Samsung dv219agw dryer shuts off with no lights on control pannel or sounds. If you open the door the light inside comes on but that is all.
  • Samsung Master
  • 19,396 Answers
It sounds like a faulty timer board. As first thing check lint filter and replace the thermal fuse.
The timer control board is expensive and control board failure are difficult to diagnose.
For this reason the timer board is replaced only after testing all other parts.
In your case, since the failure happens at random times, and the cycle iterrupts leaving only basic functions, concentrate the testing on the door switch and on wiring harness/connectors to the electronic control board.
The door switch can be tested jumping its contacts.
Wiring harness and connectors are tested reading Ohms between two points to ensure that there is continity.
This operation must be done with power not connected.
If there is no problem concerning the wiring, door lock and timer, test quickly the heath group , motor, and rest of the wiring to ensure that the problem is not given by a contact that get lost at random times, then proceed in replacing the timer board.
To find parts you can use the links listed here: Parts and diagrams.
If you need to call a technician, use the phone number listed on the owners manual or see Fixya directory.
Regards
Regards.
Posted on Apr 26, 2010
Inside dryer light sometimes works sometimes it doesn't
Sounds like the switch for the door is sticking. You should see a switch on the dryer that is activated when the door is opened.
Dec 18, 2015 | Kenmore Dryers
Door is ajar message when shut light comes on but doesnt run
That's because the door switch isn't getting pushed when you're closing the dryer door for some reason or another. Its located at the top of the door. Try pushing the switch by hand and seeing if the light shuts off when you manually push it.
Nov 27, 2013 | Samsung DV337 Electric Dryer
Whirlpool duet dryer doesn't work after power surge
Hello, well that sounds a fuse problem, you can try check inside, be shore you unplug the power socket before you do it, if the inside fuse is ok ,so the control board is damage and needs to be replaced, and don't think it worth .
Thanks
Nov 22, 2013 | Whirlpool Duet WED9150WW 6.7 Cu. Ft....
Whirlpool Cylypso Dryer not shutting off when
sounds like the door switch is sticking when door opens drum should stop and lite comes on, check to see if switch is sticking if not then you should probably replace it also chec bulb to see if it is not burned out.You never know one could probably effect the other
Dec 18, 2009 | Dryers
Unit not running, no lights on pannel but lights work inside.
Could be a control board issue, a broken wire somewhere, maybe the plug came off of the board. Try to unplug the refrig and plug it back in....A lot of times that will reset the board
Sep 13, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Neptune MDG4000BWW
check your door switch it might be broken. push the door switch in with your hand. does the light turn off? if no this is your problem
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool LER8620 electric dryer, shuts off at random. When it
Whirlpool Dryer Won Start
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
Samsung DV219AG Dryer Logo
258 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
