Samsung LN-T3253H 32 in. LCD Television
Problem for Samsung LN-T3253H 32 in. LCD Television
New Samsung Tv High pitched hum
By Cassidy313 on Mar 24, 2008
I purchased a new 26 inch Samsung LCD Tv and noticed after a few days that there was a high pitched hum coming from the top end of the TV that could be easily heard from 15 feet at low volume levels. I took the TV back to Future shop and they gave me a new one. I also purchased a clean power bar and a digital cable box and plugged everything into the clean power bar. The hum is back.
I have purchased a new dvd player and hooked it up to the TV in Component Video. I have split the Cable so that one goes to the TV (little kids use that remote) and the other enters the cable box and then enters the TV using the AV mode.
What can I do to get rid of the hum. It drives me nuts.
I bought this TV through Amazon.com a few weeks ago. It works great but recently (I don't watch much TV) I've heard a high-pitched hum coming from the TV. It sounds like a slightly muffled teapot whistle. It's awful! I have Bose speakers hooked up and can still hear the hum even if they're at a high volume! Has anyone found out what causes it, or how to fix it?
Same Problem
Dec 07, 2008
-   My Samsung LN-T3253H TV is whistling after it's been on for awhile. It is SO annoying! The whistling continues even when the sound is muted.I alo have a report in to Samsung and they are sending a technician out. I heard there was a bad part in some models that they will replace. I uploaded my circuit city receipt on the repair request web site. I hope they can fix it! -   Guest
Jun 22, 2008
-   yes same think after it is on for 1hr -   Guest
May 19, 2008
-   I recently purchased a samsung #LN2653H from sears. It was a floor model and what I thought was a great deal. Now a horrible high pitched noise comes out of the back, and this noise lingers in my ear long after the set is turned off. I don't think I have a warranty because it was a floor model but can still purchase the extended warrantyfrom sears. Does anyone know if this warranty will help, or does samsung stand behind sears floor models?-   Guest
Apr 30, 2008
-   I have the same prob in Colorado. My samsung 32" LCD makes the high pitch noise. Darn it? Take it back I shall. Now, My 52" plasma by samsung does not do that.
-   Guest
Apr 27, 2008
-   I'm experiencing the same high pitched noise. I too have Bose system connected with the TV volume programmed off. The high pitched whistle is heard best when Bose system sound is muted. Noise definately coming from TV electronics.
Noise began after ~3 months of service.
I purchased this Samsung LN-T3253H through Buy.com, Dec. '07-   Guest
Best Solution
posted on Apr 04, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
There is a specific reference to this condition on the Samsung support website. My new LN-T3253H had the same whistling problem when I first started using it. Several days into use the whistle has subsided somewhat. I entered a tech support case on the Samsung support site and Samsung is sending a technician to my home to perform a repair - no charge as unit is still under full manufacturer's warranty.
Solution #2
posted on Mar 24, 2008
Helpful)
Computes
Rank: Guru
Rating: 95%, 182 votes
The best answer is to return the set to the store and get a different brand. This set was made with this problem. If you complain to Samsung customer support they should get you a defferent tv or a new power supply board for this set.
Was this helpful?
Yes
No
Solution #3
posted on Aug 21, 2009
Very Helpful)
HateSamsung
Rank: Apprentice
Rating: 100%, 4 votes
Don't know if people are still having this issue or not but figured I'd post what i went through to help anyone that has. My LN-T3253H tv as out of warranty when I finally got around to calling Samsung. They flat out lied about the commonality of this problem and I convinced them to at least pay for any parts. Problem is the labor of a technician would be around $150. So, I bought the new power supply from Partstore.com for around $70. Just go to partstore.com and enter your model number and look for the power supply on the page. It took 3 days to get the part. It was very easy to replace. All you have to do take off the back cover of the tv (think there were around 12 screws all around the outside and one where the A/V connections are and pull off. Unhook the plugs going to the power supply and the four screws holding the board and then replace with the new board. So far, this fixed the issue. Keep your old board in case it starts happening again. You can probably have the old board repaired to fix the original problem since so many TV repair shops are aware of the issue. I am trying to find out from someone which specific capacitor or other piece is causing the issue and plan on fixing it myself. If and when I do, I will also post that.
Make sure you give Samsung a ton of grief when you speak to them and see if they lie to you also. I had just bought two of the new Samsung LED TV's for my media room. They work great but I returned both because of Samsung's refusal to fix my LN-T3253H and I will never, ever buy Samsung products again.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #4
posted on May 26, 2009
Helpful)
lackofzzzzzz
Rank: Apprentice
Rating: 88%, 2 votes
It's the power supply unit....a transformer needs to be soldered. Read this link for more onfo....
http://forums.cnet.com/5208-7596_102-0.html?threadID=288816
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Samsung LN-T3253H 32 in. LCD
Questions and Unsolved Problems for Samsung LN-T3253H 32 in. LCD
Do you recommend Samsung LN-T3253H 32 in. LCD Television?
Answer
Answer
After trying to turn the channel yesterday on my Samsung LCD HDTV (32"), a black box in the top... (More)
Answer
TV went out while watching DVD. It will not turn on now. Red "on" light goes on and off
Answer
Has an annoying high pitched ring in the background
Answer
Using digital cable. Screen went black, but can still hear sound. Checked all connections, reset... (More)
Answer
I have a samsung LNT4665fx. It turns on just fine, and the screen looks normal. After about 15... (More)
6 Other Users Have The Same Problem - Continued
Comment by drunkmonkey, posted on Apr 16, 2008
I have the exact same problem! The first time I immediately returned it to Futureshop for a replacement. A few months have gone by and now the noise is back with my second TV. The noise occurs after the TV is on for 30 mins.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Samsung LN-T3253H 32 in. LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 790
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
