I have a sanyo M9978F stereo radio cassette recorder. It was dropped. Now I have a loud hum coming from my left speaker when I play a cassette. Its ok when I play radio. Just when the tape is playing.
  • Patrick McAlexander Apr 28, 2010
    Thanks for the response. I checked, and the only ground strap I found was still connected. Wouldn't that also affect the FM radio also? Would the heads being out of alignment cause this too? Thanks for your help.
  • Patrick McAlexander Apr 29, 2010
    I found the ground wire. Thank you for your help.
    President:
  • 1,469 Answers
you can check the ground cable by opening the cassette player to check f the ground cable has pulled off.
When it pulls off, you will get a hum sound. So you can check if the cable has been bulled out. fix it back and the hum sound will stop.
Take care.
Posted on Apr 28, 2010
  • Egwe Emmanuel Onyedikachi
    you can also check other electrical areas that high ground wires too,
    you will surely find one that has removed that is causing that hums.
    Take care.
Radio trouble shooting
It seem like the stereo for the radio is failing, either because of a weak radio signal or defective aerial
Jul 30, 2014 | Mercedes-Benz 1992 Mercedes 500SL Radio /...
Hi i have connected the Samson G-track with my macbook. also i using Nicecast & Traktor for radio broadcasting. when i talk from Samson G Track my voice comes only from left speaker. I try the...
This is because the G Track's Mic signal is on the Left channel and the Instrument signal is on the Right channel. You are making a stereo recording when you should be making 2 mono recordings. Does Nicecast have an option to set the track to mono Left channel? Traktor should, but I haven't used it so I can't tell you where the option is. There's probably a Track Input drop-down or something like that.
Sep 12, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
Sound only comes out on one side of earphones -- tried 4 different headsets and all the same. Any suggestions?
You are probably connecting a stereo headset and this model only accepts a mono headset. You can get a stereo to mono adapter at Radio Shack for about $3.
Dec 27, 2010 | Sanyo TRC-6040 Desktop Cassette...
Reorded tapes only play out one speaker
check your cables to the units channel that doesn't work, for breaks. Does the cassette player play back a pre-recorded tape okay? if it doesn't there might be a internal fault.
Check the wires to the tape head to see if one is off.
Jun 06, 2009 | Kenwood CT-201 Cassette Player Single Dual...
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 03, 2009 | JVC KW-XC777 CD / Cassette Player
Stereo cassette receiver--hums
There could be an open filter capacitor in the power supply.
Jul 13, 2017 | Kenwood Audio Players & Recorders
Wont record blank cassettes? Any ideas?
it probably does need a microphone. check for an input plug on it.
Jun 05, 2017 | Spectra Hello Kitty KT2028...
51 people viewed this question
 Grubhead
Grubhead
