Question about Dell Inspiron 1501 Notebook
I have a Dell Inspiron 1501 with Windows Vista. I need to restore it to factory settings. I did this one time a couple of years ago, but don't remember how I did it. I do remember it took me forever to figure it out, I wish I had wrote it down. I have the Dell Windows Vista DVD, and the discs for drivers, programs, etc. I just don't know what to do with them. I tried putting in the Windows DVD, then restarting the computer, and booting from CD ROM. The only thing that happens is, it says "Windows is loading files", or something like that, with a white bar moving back and forth at the bottom. Then, when it gets done, after about 2 minutes, the laptop shuts off. Then it doesn't come back on, even after 15 minutes. So I tried some other things. I tapped the F8 at startup before the logo appeared. I got an advanced boot menu, but there was no option for repair computer. Or to restore. There isn't anything I can use on F2 or F12 either. There is a drive on my computer called Recovery. On this drive is a folder with Dell things, and one folder said tools. In this tool folder is a application that says PCrestore. I tried it, it wanted me to run it as administrator, so I did. I clicked to restore, and after the bar moved about 1 and a half times, it stops, and says error. So how can I do a system restore, I do have all the discs that I got from Dell when I was still under warranty. Someone please help. I've got some bad things on this laptop, like something called Antispyware Soft, which I heard is a rogue program or virus. That and a bunch of other problems.
  • Dell Master
  • 1,183 Answers
Thanks for being so descriptive about the problem you are having with the system. Since the laptop is shutting down and does not come after 15 mins. First you need to run the diagnostics on the system.
1. Shutdown the laptop disconnect it from the AC adapter and remove the battery.
2. Press the power button for 10 sec( this done to remove any residual charge from the motherboard)
3. Re-insert the battery and Re-connect the Ac adapter.
4. Press the Fn key and power button to run the diagnostics.
Note down and repost any error messages.
You can follow the link below for the step by step instruction to reset your computer
http://tinyurl.com/y9e8ogf
Thanks for using fixya
Proton
Posted on Apr 26, 2010
Want to restore to factory settings. running windows 7 ultimate
Anonymous,
There are a couple of ways to Restore the system to the factory image. It depends on the system. Some older systems you would start the computer and press CNTRL+F11 and choose to restore. Other systems you would start the computer and TAP the F8 key and choose "Repair Your Computer" and follow the prompts to restore. Newer systems use a program called Dell Datasafe Local Backup accessed from the F8 advanced menu.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 11, 2015 | Dell Inspiron 1300, 1501, 6400, 9200,...
I have a dell involve laptop while i was trying to set back to factory specks i got locked out and it wont let me access any thing with out my administrator password and i don't no it what can i do to save...
No laptop is trashed when a password is lost. It just takes a little time to find out how to get into the system. I'll assume it is running XP Home that was originally installed on it from the specs I saw when researching. I'll also assume the password is not the one necessary to get into the BIOS CMOS setup- that one can normally be cleared by removing the CMOS battery and letting it set for a few hours or longer so the information is lost. The OS password can be cleared by making a bootable disk for that purpose. I have a Unix CD program that I made from information I downloaded from the Internet. You can do the same if you have access to a CD burner on another computer, say a friend's or one at work. I can get you the program's name if that's the route you want to take.
Dec 23, 2014 | Dell Inspiron 1501 Notebook
How do I reset to factory settings without the disk
In order to reset your computer to Factory default settings without the disc, you can follow the instructions below.
1. Turn on your computer. Once you see the DeLL Logo Press and Hold the CTRL button then while holding CTRL button, press F11
2. You should see the Dell PC Restore by Symantec application.
3. You can click Restore and Confirm the restoration.
4. It will take 10-15 minutes. Once your computer rebooted, it should already be in the default settings
Apr 04, 2011 | Dell Inspiron 1501 Notebook
All i want to know is HOW DO YOU REBOOT A DELL INSPIRON 1545 TO FACTORY SETTINGS I DON'T HAVE THE MONEY TO TAKE IT IN.
Windows Vista: Dell Factory Image Restore
  1. Turn on the computer. When the Dell logo appears, press several times to access the Vista Advanced Boot Options window.
  2. Select Repair Your Computer.
The System Recovery Options window appears.
  1. Select a keyboard layout and click Next.
  2. To access the recovery options, log on as a local user. To access the command prompt, typeadministrator in the User name field, then click OK.
  3. Click Dell Factory Image Restore.
note.gif NOTE: Depending upon your configuration, you may need to select Dell Factory Tools, then Dell Factory Image Restore.
The Dell Factory Image Restore welcome screen appears.
  1. Click Next.
Nov 09, 2010 | Dell Inspiron 1545 Notebook
Reset a inspiron 1501 how ?
really hate when people start talking bs without knowing all the facts.. there IS a 5 min factory reset magic button or buttons
restart your computer when you see the dell screen press CTRL+F11 follow the steps mine too about 3 minutes
if your computer is older then 4 years I think its F8
Jan 02, 2010 | Dell Inspiron 1501 Notebook
How do i return to factory setting on a dell pc
If the operating system is windows vista, restart your computer and when you see the dell logo, press f8. you should see advanced boot options. choose 'repair your computer'. then it will ask for the keyboard and language layout. just choose english then click next. then logon. after that it will show the windows recovery screen. just choose to restore to dell factory settings. It will bring all the settings back to factory defaults. But it will delete all your files so make you back them up first. :)
Nov 23, 2009 | Dell Inspiron 1501 Notebook
I have exactly the same problem :-(((
On this link: "http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=INS_PNT_PM_1521&hidos=WLH&hidlang=en&TabIndex=" try to check of what OS that you are using, if it is Windows XP or Windows Vista.If you are using Windows Vista and still not compatible things happen that you need to backup all of your important files and have to do a DELL PC RESTORE. Restoring your computer settings from factory. Everything on it will be gone. So again, make sure to backup the files. But in a case still nothing happens, then have to call Dell technical support for assistance. There would be a scenario that your audio device is working badly that needs to be replace which is the motherboard. Thank you.
Oct 09, 2009 | Dell Inspiron 1501 Notebook
How do i restore my dell inspiron 1501 to factory settings without the disc? i lost it and im goin nuts...
Contact Dell to purchase a Recovery CD for your model Dell laptop.
The other way is to do a new Windows install. Use a Windows installation CD, it must match the Windows version on the Windows Product Code label on the bottom of your laptop.
You will also need to download the device drivers for your model laptop from the Dell WEB support site, make sure the download the correct XP or Vista version of the drivers that match the Windows version you are installing.
Sep 07, 2009 | Dell Inspiron 1501 Notebook
How to get factory settings for my Dell Inspiron 1505
If you have Windows Vista you can press F8 while booting to access the Windows Startup Repair and then select the Factory Image Restor.
Dec 09, 2008 | Dell Inspiron 1501 Notebook
I need to restore to factory like status a Dell Inspiron 1501.
If you have a restore xp/vista cd. Just do a reinstall. If it is a vista, you will need to call microsoft for a new certificate.
Dec 06, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
162 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
