Question about Canon BubbleJet i550 InkJet Printer
Canon i550 dosen't print?
  • 4,041 Answers
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 26, 2010
I have got Canon i560 printer but not recieving print order the software is loaded what is the solution ?
Try i560 Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Pl let me know if this works
Nov 12, 2010 | Office Equipment & Supplies
Canon i550 yelow light on: "operator error" . Have tried to resume and delete printing tasks and restarted printer
Had the same problem with my I550. Was going to buy a new printer (I4000) since I could get one for about $30 more than the price of a new print head. I like canon printers with the individual ink tanks and have had no problems with the I550 for about three years.
Decided to try moving the paper thickness lever back an forth a number of times since some of the error messages indicated it could not determine the setting of the paper thickness lever. I don't know how the printer determines this switch setting but I thought if some contacts are slightly oxidized that movement might break up some of the oxidation. After operating the lever about a dozen times the printer started working. Hope this will help.
Oct 12, 2009 | Canon BubbleJet i550 InkJet Printer
Canon i550-turn on-orange/green 8x then long green
From the Canon website:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i550
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
For the Waste Tank Reset Code, and how to repair or replace the Waste Tank, see this website:
http://www.bioscomputers.ca/CanonWasteTankCodes.htm
Jul 16, 2009 | Canon BubbleJet i550 InkJet Printer
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same time. linda gal 16
try looking under the propertys page for the printer and see if its set to print black only or gray scale. if so set it to auto and you should be ok if the printer and cartrige is ok.
Jul 08, 2009 | Canon BubbleJet i550 InkJet Printer
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same timeannabellamt
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same time. linda gal16
Jul 06, 2009 | Canon BubbleJet i550 InkJet Printer
Is there something wrong with my Canon i550 printer head?
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 03, 2009 | Canon BubbleJet i550 InkJet Printer
Canon i550 printer stoipped printing
My cannon printer no longer responds to any commands. I get 4 yellow blinking lights and then 1 green blinker.
Oct 09, 2008 | Canon BubbleJet i550 InkJet Printer
Canon i550 will not print
Have you checked the settings in the Manual?
If it's missing you can download from
http://software.canon-europe.com/software/0023008.asp?model=
Aug 30, 2008 | Canon BubbleJet i550 InkJet Printer
Canon i550
Download the driver from Canon website, look at support page.
What operating system are you using ?
Feb 17, 2008 | Canon BubbleJet i550 InkJet Printer
Canon BubbleJet i550 InkJet Printer Logo
118 people viewed this question
old marine
old marine
