Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Warped 3D vision on the screen
Rca hd 47" monitor( not the flatscreen)
one minute was clear as could be, and now it turned to a weird warped vision with a 3d vision and color to it. i've been looking for the auto color configuration program on it but it seemed to have disappeared.
    Genius:
  • 1,030 Answers
Convergence is out? convergence is not available in setup menu? this points to eather convergence power supply out or you might wont to look at fl231 fuse.
Posted on Mar 24, 2008
Tv screen went black...I can still hear the audio. What could be the cause?
This is a tricky one as this could be a number of things, with very little to go on, More info is required, but try this.
First check that all cables are fully inserted properly.
They may look OK but just give them a push to make sure.
Dec 30, 2013 | Vizio 47" M3D470KDE 3D Full HD LED-LCD...
I have a LG 47 inch flatscreen.i cant find any audio output plugs to hook it up to surround sound.how are you supposed to hook it up.
this is from the LG website about that TV.
- Rear,
2 x Composite video/audio input (RCA phono x 3) - Side,
2 x S-Video input (4 pin mini-DIN),
1 x USB (4 pin USB Type A),
1 x Audio line-out (RCA phono x 2),
2 x Component video input (RCA phono x 3),
2 x Audio line-in (RCA phono x 2),
1 x Digital audio output (optical) (TOSLINK),
1 x Digital audio output (coaxial) (RCA phono),
3 x HDMI input (19 pin HDMI Type A),
1 x RGB input (15 pin HD D-Sub (HD-15)),
1 x Audio line-in (Mini-phone stereo 3.5 mm),
1 x Serial (9 pin D-Sub),
1 x Remote control (Mini-phone 3.5 mm)
Mar 20, 2011 | LG 47LC7DF 47 in. LCD HDTV
I'm getting a green / red separation on my screen now. Nothing I do seems to help. This a 2002 projection, HDTV 1080i, Cinema Vision unit.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2011 | Panasonic PT-47WX49 47" Rear Projection...
My TV (module # KP-57WS500) is in a weird double vision view as if it is in 3D. with blue,red, colors. top and bottom of the screen also curve into the center of the tv. worked perfectly fine night...
  • Screen looks 3D
69189a5.pngSOLUTION
Nov 24, 2010 | Sony KP-57WS500 57" Rear Projection...
I have a 52" RCA HD. I turned it on and for a few minutes it played great. Now the screen appears warped on the top and bottom.
This is a 52" RCA DLP projection tv correct?Yes,than a problems,u have is known as a convergence problems,it dead.The colors lines R,G,B mis alignment,have colors shadow pictures or 3D pictures.The tv convergence board,the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 14, 2010 | RCA Televison & Video
Tv looks blurry on the right side
You will also find there is colour disorientation in these areas. The reason is that your settings on the york had shifted, also it could be due to failure of the degaussing coil, or if there is any fault with the convergence inside the picture tube which could be a major fault.
Try to degauss, see the picture tube neck for any ring magnets out of alignment, also check the focussing in the rear panel which could have shifted.
Jun 08, 2010 | Panasonic PT-47WX49 47" Rear Projection...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA HD 61w66 color is messed up...
problems like that is caused by moisture inside the unit.sometimes it goes back, like nothings happened.but, if not a tech is the only option.
May 20, 2009 | Televison & Video
3D like view on my screen
you ned to replace both convergence ICs they are STK392-570 you can get replacement ICs at the following link with free installation instructions.
http://servicemanuals.vstore.ca/
Aug 21, 2008 | Mitsubishi WS-55819 55" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
106 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
