CONVERGENCE CHIP PHILLIPS REAR PROJECTION
WHAT IS A CONVERGENCE CHIP PHILLIPS REAR PROJECTION
  • 597 Answers
Needed to perform the convergence repair..
Call their tech support
Posted on Apr 26, 2010
Im looking for a projection alighment chip for 60pp9202/17f phillips
you will require two of the STK392-120 Convergence ICs and possibly the 6.8 ohm resistors. The Phillips DPTV305 - DPTV335 convergence repair kit available from www.tvrepairworld.com has the two ICs and the 12 resistors plus the CD with repair instructions.
Sep 25, 2011 | Philips 60PP9202 60" Rear Projection...
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
Phillips 51pw93 blue convergence chip bad.
Way to risky to replace one , besides
they are cheap 10.00 -20.00 etch
the load ballance is also offset from
0ne chip to another. They need to
be replaced as a set
Jun 30, 2009 | Televison & Video
Convergence problem that won't correct itself with the convergence menu.
You can get the convergence repair kit at the following link which contains the parts and step by step detailed instructions. The DPTV305-DOTV345 phillips convergence kit is the one you need listed under the phillips repair kits.
http://www.tvrepairkits.net/home
Jun 25, 2009 | Philips Magnavox 9P6034C 60" Rear...
Need to replace conversion chip or small signal board
You can get the repair kitfor that issue for your model at the following link which contains both convergence ICs, the 12 feed resistors and free step by step instructions with pictures on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
May 22, 2009 | Philips Magnavox 51MP392H Rear Projection...
Phillips 60PP9363H/17 Picure warped and collor drifting
You have a convergence chip problem. You need to get a kit from www.TvRepairKits.com.
Note: The longer you run your set with a convergence problem the more problems you will have. Turn it off and get it fixed.
Nov 14, 2008 | Philips 60PP9363 60" Rear Projection...
My Phillips 60PP9202 60 lost it's blue hue
No sure what you mean the color changed. That could be caused by many reasons, and the most common is a bad convergence chip. Here is my regular response message to convergence problems:
You most likely have a convergence chip bad. In our shop, when we are working on projection TVs, we find that about 80% of the repairs we make are the same problem you are having. You need to replace the convergence chip ( there are 2 of the same chips on the convergence board, and I suggest you replace both ). If you are going to attempt the repair yourself you'll need to remember to use lots of heat sink grease so you don't have the same problem again. Also, try to get original parts, as there are times that the after-market ones don't work well. As a precaution, always remember to unplug the set from the wall before you do any work on the set. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 31, 2007 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP9202 Convergence Problems
The two convergence IC's are generic part# STK392-120 (Philips original part# 932212344682) The two resistors are sitting side by side (6.8 ohm 2 watt)
Sep 15, 2007 | Philips 60PP9202 60" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
