Question about Trendware TRENDnet TEW-435BRM 802.11g 54Mbps ADSL Modem Router with 4 Port Switch (NETWTW435BRM)
Trying to configure the computer TCP/IP setting but not getting the result.Computer not successfully connected to the router
    President:
  • 1,768 Answers
1. Use a know good straight through cable
2. reset the router
3. release/ renew the IP
4. Make sure you have DHCP set to automatic
Posted on Apr 27, 2010
I am not able to connect to the internet using my Linksys WRT54G V8. When I connect the cable directly to my laptop, I am able to access the internet, so it is definitely a problem with the wireless...
Title: Setting-Up a Wired Computer to Obtain an IP Address Automatically Article ID: 4033
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 29, 2010 | Linksys Wireless-G WRT54G Router
Tip
Setting up a Router
Chapter 1: Connecting the Wireless-G Broadband Router
Hardware Installation
1. Locate an optimum location for the Broadband Router. The best place for the Broadband Router is usually at the center of your wireless network, with line of sight to all of your mobile stations.
2. Fix the direction of the antenna. Try to place it in a position that will best cover your wireless network. Normally, the higher you place the antenna, the better the performance will be. The antenna's position
enhances the receiving sensitivity.
3. Connect a standard Ethernet network cable to the Broadband Router’s Internet port. Then, connect the other end of the Ethernet cable to your Cable or DSL Broadband modem.
4. Connect your network PCs or Ethernet devices to one of the Broadband Router’s numbered ports with a standard Ethernet network cable.
5. Connect the AC Power Adapter to the Broadband Router's Power Socket and the other end into an electrical outlet. Only use the power adapter supplied with the Broadband Router. Use of a different adapter may result in product damage.
Chapter 2: Configuring the PCs
Overview
The instructions in this chapter will help you configure each of your computers to be able to communicate with the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/ IP) address automatically, so your PC can function as a DHCP client. Computers use IP addresses to communicate with the Router and each other across a network, such as the Internet.
First, find out which Windows operating system your computer is running.
You can find out by clicking the Start button. Read the side panel of the Start menu to find out which operating system your PC is running.
You may need to do this for each computer you are connecting to the Router. The next few pages tell you, step by step, how to configure your network settings based on the type of Windows operating system you are using. Make sure that an Ethernet or wireless adapter (also known as a network adapter) has been successfully installed in each PC you will configure.
Configuring Windows 98 and Millennium PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network icon.
2. On the Configuration tab, select the TCP/ IP line for the applicable Ethernet adapter. Do not choose a TCP/ IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/ IP appears by itself, select that line. Click the Properties button.
3. Click the IP Address tab. Select Obtain an IP address automatically.
4. Now click the Gateway tab, and verify that the Installed Gateway field is blank. Click the OK button.
5. Click the OK button again. Windows may ask you for the original Windows installation disk or additional files. Check for the files at c:windowsoptionscabs, or insert your Windows CD-ROM into your CD-ROM drive and check the correct file location, e.g., D:win98, D:win9x, etc. (if “D” is the letter of your CD-ROM drive).
6. Windows may ask you to restart your PC. Click the Yes button. If Windows does not ask you to restart, restart your computer anyway.
Configuring Windows 2000 PCs
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dial-up Connections icon.
2. Select the Local Area Connection icon for the applicable Ethernet adapter (usually it is the first Local Area Connection listed). Double-click the Local Area Connection. Click the Properties button.
3. Make sure the box next to Internet Protocol (TCP/ IP) is checked. Highlight Internet Protocol (TCP/ IP), and click the Properties button.
4. Select Obtain an IP address automatically. Once the new window appears, click the OK button. Click the OK button again to complete the PC configuration.
5. Restart your computer.
Configuring Windows XP PCs
The following instructions assume you are running Windows XP with the default interface. If you are using the Classic interface (where the icons and menus look like previous Windows versions), please follow the instructions for Windows 2000.
1. Click the Start button and then the Control Panel icon. Click the Network and Internet Connections icon. Then click the Network Connections icon.
If you would like more information on setting up your connection, please post your questions and I will surely respond.
Also for any clarification, you can email me at titilayosodipe@live.com
Best regards.
Sholly-NG
on Jan 07, 2010 | Computers & Internet
Tip
Setting up a Router
in product damage.
Overview
the Router.
To do this, you need to configure your PC’s network settings to obtain an IP (or TCP/IP) address automatically, so
First, find out which Windows operating system your computer is running. You can find out by clicking the Start
2. On the Configuration tab, select the TCP/IP line for the applicable Ethernet adapter.9641e30.jpg
Do not choose a TCP/IP entry whose name mentions DUN, PPPoE, VPN, or AOL. If the word TCP/IP appears by
3. Click the IP Address tab. Select Obtain an IP address automatically.a443500.jpg
1. Click the Start button. Select Settings and click the Control Panel icon. Double-click the Network and Dialup
Connections icon.
Connection listed). Double-click the Local Area Connection. Click the Properties button.ea4fa3a.jpg
3. Make sure the box next to Internet Protocol (TCP/IP) is checked. Highlight Internet Protocol (TCP/IP), and click
Connection listed). Double-click the Local Area Connection. Click the Properties button.f2e300e.jpg
If you would like more information on setting up your connection, please ask me a question.....
Cheers.
on Jan 03, 2010 | Computers & Internet
How do I hook up your router to make my laptop be wireless........it has to go through a contrend router that is on my desktop computer
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 10, 2010 | Linksys Wireless-G WRT54G Router
My WRT54G wireless router does not connect to our laptops. The (4) wired ports work fine. What am I doing wrong?
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 05, 2010 | Linksys Wireless-G WRT54G Router
Tip
Full details on how to set up your Wireless-G WRT54G Router
in product damage.
Overview
the Router.
Check for the files at c:\windows\options\cabs, or insert your Windows CD-ROM into your CD-ROM drive and
check the correct file location, e.g., D:\win98, D:\win9x, etc. (if “D” is the letter of your CD-ROM drive).
Connections icon.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
on Jun 28, 2008 | Linksys Wireless-G WRT54G Router
My router stopped working
Try to create a new connection.
in product damage.
Overview
the Router.
Connections icon.
2 linksys200 ? configurer sur le meme reseau
in product damage.
Overview
the Router.
Connections icon.
Jun 23, 2008 | Linksys Computers & Internet
Linksis wireless computer setup for WRT54G model
in product damage.
Overview
the Router.
Connections icon.
Dec 28, 2007 | Linksys Wireless-G WRT54G Router
Macintoshes and the RP614 Router Gateway
You need a Macintosh computer running MacOS 8.6, 9.x, or 10.x. (Netgear products are not supported for versions of MacOS before 8.6.) You can use the RP614 with an eMac, iBook, iMac, PowerBook, PowerMac, or PowerPC as long as they are running one of these versions of MacOS. You also need a few Ethernet cables to make the connections between the router to your modem for internet connection and from the router to your computers or peripherals. Topic 2. How do I prevent my Network configuration from being lost when I restart my computer? When making configuration changes for MacOS it is best to use Configurations (MacOS 8.x or 9. x) or Network Location (MacOS 10. x) settings instead of just changing settings for each category (TCP/IP, AppleTalk, AirPort, etc.). If you just make changes to your settings, they may be lost when you restart your computer unless you have saved them in a Configuration or Network Location. To create a Configuration in MacOS 8.x or 9.x: 1. Open AppleTalk (or TCP/IP) from the Apple Menu in the upper left-hand corner of the screen. 2. From the pull-down File menu select the Configurations option. 3. Choose New Configuration. 4. Type in a name for your new configuration (Netgear Router). 5. Make your changes to the AppleTalk (or TCP/IP) settings. 6. When you close AppleTalk (or TCP/IP) choose Save Changes. Whenever you make Configuration changes for settings in MacOS 8.x or 9.x, open Configurations from the File menu or by pressing Command-K. Saving your changes in Configurations means that they will not be lost when you reboot your computer. To create a Network Location in MacOS 10.x: 1. Open the Apple Menu by clicking on the Apple icon in the upper left-hand corner of the screen. 2. Select System Preferences. The System Preferences window displays. 3. From the System Preferences window click Network under Internet & Network. The Network settings window displays. 4. Click the Lock icon (if necessary) in the lower left-hand corner of the window to unlock the Network window so you can make changes. (You may be asked to type in your User Name and Password.) 5. Click the pull-down menu next to Location at the top of the Network window. 6. Select the New Location option. 7. Type in a name for your new Location and click OK. 8. Make your changes to the TCP/IP, AppleTalk, and AirPort settings. 9. Click the Lock icon in the lower left-hand corner to prevent further changes. The Apply configuration changes? Window displays. 10. Click Apply to apply the configuration changes for the newly-created Location. 11. Close the Network window. Topic 3. How do I connect a Macintosh to the RP614 Router Gateway? MacOS 8.6, 9.x, and 10.x 1. Set up your system for installation. 2. First make sure your ISP connection is working. Try testing your computer with the ISP directly to make sure you can successfully make a connection to the internet. 3. Connect your DSL or cable modem to the Netgear Router. 4. Log on as Administrator (if required for your system to make configuration changes). 5. Quit all other applications. It's best when configuring MacOS 8.6 and 9.x to use the Configurations settings for AppleTalk and TCP/IP because they should then retain their settings when you reboot. (Use Network Locations to save your settings changes in Mac OS 10.x.) If you just change the settings but don't use a Configuration or Network Location to save your settings changes, you may lose those changes when you restart your computer.
Feb 19, 2006 | NetGear RP614 Router
Trendware TRENDnet TEW-435BRM 802.11g 54Mbps ADSL Modem Router with 4 Port Switch (NETWTW435BRM) Logo
118 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
