Question about Ace Hardware Pacemark® 4410 Matrix Printer
Laminator does not heats up?
Laminator lervia KH 4410 does not heats up?
Why is my laminator not taking pouches?
check the thickness setting as there may not be enough pressure on the roller
Jul 21, 2017 | The Office Equipment & Supplies
Has someone got a manual for lervia 564
This site lists manuals for Lervia (although not your model), however, sometimes machines are sometimes similar enough that other manuals are helpful:
http://safemanuals.com/page/search/Lervia+564
Kompernass LERVIA KH 4000 Operating Instructions Manual
May 27, 2016 | Sewing Machines
Does the GBC Ultima 65 have an adjustable pot to increase heat of rollers? If so, where is it located?
Ordinarily, laminators have speed controls to allow the laminated substrate to get hotter.
Feb 12, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
Laminator won't heat up
This is just rediculous. Where's the friggin answer?
Mine won't even come on. JUNK!
Jan 28, 2014 | Gbc HeatSeal Ultima 65 Laminating System
What is the difference between cold and hot laminators?
Hot laminators are the most common types of laminators. They use heat (220 to 300 degrees F) to apply the lamination. Hot laminators provide a better quality lamination that is more resistant to wear and tear. This is the preferred method of lamination for materials that are not effected by heat.
Cold laminators use pressure sensitive adhesives to bind the lamination film when the material being laminated is sensitive to heat. Certain inks in standard ink jet printers are known to have the ink melt in the machine. There are other types of printers that use heat sensitive paper. For these types of applications the cold laminator is the best choice.
Jan 28, 2013 | Office Equipment & Supplies
I have a Lervia cross cut paper shredder model KH 4404 and have misplaced the users manual. Is it possible to obtain a copy of this.
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 19, 2010 | Office Equipment & Supplies
Ace Hardware Pacemark® 4410 Matrix Printer Logo
173 people viewed this question
Top Ace Hardware Office Equipment & Supplies Experts
k24674
Are you an Ace Hardware Office Equipment and Supply Expert? Answer questions, earn points and help others
