Question about Roper REX4634KQ Electric Dryer
Heat is not always coming on in dryer. Roper dryer from Lowes
When I turn on the dryer, sometimes the heat comes on and drys in one cycle. Most of the time the heat initally comes on then turns off. It takes 2 or 3 cycles to dry clothes. We tore apart dryer and can feel the heat come on, but when put back together, it would not heat. problem seems to be intermittant. Sometimes it works, sometimes it doesn't. We wonder if it is in the dial or thermostat.
    Novelist:
  • 145 Answers
There are numerous temperature sensors on the dryer. Some are near the drum, some could be near the lint filter if it is located inside the dryer door. Try changing these first as they are an in expensive fix. It could also be the heating coils themselves. Highly unlikely it would be the dial, unless the dial was accidentally turned in the wrong direction.
Posted on Apr 26, 2010
My dryers timer wouldn't work correctly and the clothes were taking forever to dry. I decided to check the vent. My advice....Always check your dryer vent before spending any money on unnecessary parts or service calls. This Nest was pulled out of my vent with my shop vac sucking out and my house vac blowing out from inside. It finally broke free and now my dryer works like new. Heat is not always coming on in dryer. Roper dryer - 4_3_2012_7_30_40_pm.jpg
Posted on Apr 03, 2012
1995 Kenmore Dryer heating issues
Sounds like a Heating element. Most towns have a do it you self appliance repair store. Contact them to price the part. Have you tryed vacuming th ling from the inside of the unit. Sometimes they get loaded with lint and does not heat efficiently. Hope this Helps.
Jun 21, 2013 | Dryers
I have a 7 cycle ele dryer (roper) my dryer is heating up but won't dry my clothes and.very little heat coming out from vent I had a new heating element put on what can be wrong with my dryer please...
When your dryer heats yet does not dry the clothes its usually always a poor air flow problem. What needs to checked is for lint build up in the blower housing,a chushed and or restricted vent from the rear of the dryer or anywhere to where it exits the house.
GENE
Sep 09, 2011 | Dryers
I have a roper changed heating element. Still blowing cool air. Sister didnt tell me it only comes on in cooldown cycle. Wats could this be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 17, 2011 | Roper Dryers
I have a Kenmore Elite dryer. It drys very inconsistently. Sometimes it works great. Other times it takes multiple cycles to dry.
heatman101
Jul 23, 2011 | Dryers
My roper dryer model rgx5634kq2 wont heat. the glow bar comes on and then goes off, other times the glow bar comes on and there is a flame, the timer only advances for certain cycles as well.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 08, 2011 | Roper RGX4634KQ Gas Dryer
Why won't my dryer heat up and dry clothes. The light comes on and the drum turns, but no heat comes from the dryer. It is a gas dryer and there is gas available. The settings are in the same cycles I've...
heatman101
Aug 01, 2010 | Whirlpool LGR7646E Dryer
REX4634KQ Electric Dryer: heater element will not come on...
heatman101
May 18, 2010 | Roper REX4634KQ Electric Dryer
My heating element is not working on my roper dryer just replaced the coil what else can it be
first check the power coming to the dryer,is it 220v. next make sure the heat setting is on heat. if all good i would remove the back, disconect power,then ohm out the thermostats. there should be a white plastic one with two wires this is your thermo-fuse most often the one that goes if it is open replace it and your cycling thermostat and high-limit. make sure your house venting is clean and not kinked up. good luck!
Jan 15, 2010 | Roper REX4634KQ Electric Dryer
Roper brand electric dryer will not stay hot
Sounds like it may be short cycling on the Hi Limit instead of the operating thermostat. Only way to be sure is to measure the temp inside the drum while operating with a load. Another way is to measure the voltage across the Hi Limit and it should always be zero. Lots of juice (240VAC) back there and safety is paramount.
Eric
Jun 08, 2009 | Roper REX4634KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
703 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
